Author Topic: help with lisp  (Read 1634 times)
PM
help with lisp
« on: September 29, 2020, 05:23:21 AM »
Hi . I see a video  How to design and draw parkin-ramps in AutoCAD . He use a lisp code. Is it possible to make samething like this ?
Here is the link of the video
https://www.youtube.com/watch?v=Zk6DpEXRMt0
PM
Re: help with lisp
« Reply #1 on: September 29, 2020, 12:14:17 PM »
Hi d2010. I can not understand the attack. I want to see how this code works and if the result is correct.Because in this video is not clear if the results is correct.
PM
Re: help with lisp
« Reply #2 on: September 29, 2020, 04:58:46 PM »
You remake something from scratch. You don't steal anything. were is the problem !!!!
BIGAL
  • 40 + years of using Autocad
Re: help with lisp
« Reply #3 on: September 29, 2020, 09:01:25 PM »
1 Stand back and look max grade change around 12% else crunch.
2 Double reverse curves use radius 13m.
« Last Edit: September 29, 2020, 09:12:04 PM by BIGAL »
d2010
Re: help with lisp
« Reply #4 on: October 06, 2020, 03:29:59 PM »
I am agree wth you, but You cannot remake full-program on the public. You can share half-codes.lsp, but other person which help-you, he upload .fas or .vlx, and he send ascii.lsp to your-PM.  :cry2:
« Last Edit: October 07, 2020, 07:55:44 AM by d2010 »
