Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Partial CUI Load ACADDOC
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Partial CUI Load ACADDOC (Read 1050 times)
capsochist
Newt
on:
September 22, 2020, 05:27:19 PM »
Hi there,
I have the following block of code in my ACADDOC.lsp file which checks a few system variables upon startup. I am wondering how to add a block of code that checks whether a Partial CUI is loaded at startup in the same way as opposed to writing (
Code - Auto/Visual Lisp:
[Select]
command
"menuload"
"acad"
) which doesn't check that it is loaded, but instead just force loads it regardless.
[Select]
foreach
sys
pdfshx
0
epdfshx
0
imageframe
2
pdfframe
2
pellipse
1
fontalt
"arial"
if
getvar
car
sys
apply
setvar
sys
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Partial CUI Load ACADDOC
Reply #1 on:
September 22, 2020, 08:17:06 PM »
To quote Autodesk.
(menugroup groupname)
If groupname matches a loaded menu group name, the function returns the groupname string; otherwise, it returns nil.
Write a If to check if not then menuload.
Logged
capsochist
Newt
Reply #2 on:
September 22, 2020, 08:55:47 PM »
this seems to work...
[Select]
if
not
menugroup
"acad"
progn
command
"menuload"
"acad"
Last Edit: September 22, 2020, 09:11:01 PM by capsochist
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
