Author Topic: MgdDbg for Autocad 2021?  (Read 2447 times)
Atook
  • AKA Tim
« on: September 22, 2020, 02:43:06 PM »
Does anyone have a working copy of MgdDbg for Autocad 2021 they could upload for me?
The one for 2019 won't work, and I haven't figured out how to compile it for 2021.
huiz
  • Certified Prof C3D
Re: MgdDbg for Autocad 2021?
« Reply #1 on: September 23, 2020, 01:18:46 AM »
Here you go.
Atook
  • AKA Tim
« Reply #2 on: September 23, 2020, 10:05:39 AM »
Thanks huiz! And it works on MLeaders now! 8-)
Did you make this, or find it?
huiz
« Reply #3 on: September 23, 2020, 11:57:56 AM »
I took the latest version from here:
http://www.theswamp.org/index.php?topic=54545.0
Jeff H was the last author, maybe he added mleaders, or it works accidentally good now  ;D
I just set the latest .NET version and did a rebuild for 2021.
Jeff H
« Reply #4 on: September 23, 2020, 02:06:48 PM »
I think I just commented out the lines that threw an error for mleaders.
Atook
  • AKA Tim
« Reply #5 on: September 23, 2020, 03:29:59 PM »
Thanks Jeff! So glad I can trouble shoot mleaders now, that was driving me nuts..🙏
I used the swamp search feature, but couldn't find that link.
I checked the link in the thread huiz linked and it was for the 2019 bundle?
It's such a good tool, maybe it's worth a stickied thread?
huiz
« Reply #6 on: September 23, 2020, 04:10:07 PM »
That one was for 2019. I downloaded it in those days and because I needed it for own use in 2020 and 2021, I copied the VS projects and did a rebuild. I did not extend it or improved it, for daily work it is a fine tool (there is also something like that for Civil 3D). I mostly use it to examin Entity Data and NOD data.
It's too bad it is not an active project anymore for Autodesk. There is a project on Github but not maintained since 2017:
https://github.com/ADN-DevTech/MgdDbg
Feel free to fork that one and continue the good work :-)
