Author Topic: very fast code question ?  (Read 1325 times)
dussla
« on: September 22, 2020, 05:56:38 AM »
hi
sorry i wonder some ~
i  am making some code
but in compex cad file ,  code is slow
so i would like to question
1.
(setq entall (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
   (vlax-map-collection entall '(lambda(x) (vla-put-visible x -1)))
2.
 (acet-ss-visible XX 0)
QEUSTION :
Is there any faster code than the one above?
Marc'Antonio Alessi
  • Marco
Re: very fast code question ?
« Reply #1 on: September 22, 2020, 06:24:02 AM »
Try with a selection set:
Function: ALE_PutVisible
; Version 2.00
; TrueFl > :vlax-true = UnHide  -  :vlax-false = Hide
(defun ALE_PutVisible (SelSet TrueFl / VlaObj Countr Count2)
; (vl-load-com)
  (setq Count2 0)
  (repeat (setq Countr (sslength SelSet))
    (setq
      Countr (1- Countr)
      VlaObj (vlax-ename->vla-object (ssname SelSet Countr))
    (and
      (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-visible (list VlaObj TrueFl)))
      (setq Count2 (1+ Count2))
  Count2
Dlanor
« Reply #2 on: September 22, 2020, 06:42:00 AM »
hi
1.
2.
QEUSTION :
Instead of checking every object, just find the invisible ones. Basically
  1. (setq ss (ssget "_X" '((60 . 1))))
  2. (cond (ss
  3.           (repeat (setq cnt (sslength ss))
  4.             (vlax-put (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) 'visible -1)
  5.           );end_repeat
  6.         )
  7. )
  8.
I haven't tested but using (entmod) may be faster, but not by much.
dussla
« Reply #3 on: September 22, 2020, 09:09:11 AM »
wow wow wow very fast
really really really thank yoyu
dussla
« Reply #4 on: September 22, 2020, 09:09:47 AM »
wow wow wow very good very good
thank you thank you ~~
