(defun c:SALL () (setq TargEnt (car (entsel "\nSelect object on layer to select: "))) (setq TargLayer (assoc 8 (entget TargEnt))) (sssetfirst nil (ssget "_X" (list TargLayer))) (princ))(defun C:FMP ; = Fillet Multiple Polylines (/ plss n) (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ)); defun
Thank you so much @Tharwat.It worked as expected !!
