Author Topic: How to select all polylines of certain layer and fillet them !!  (Read 2357 times)
JohnCamper
  • Mosquito
« on: September 21, 2020, 11:53:27 PM »
How to select all polylines of certain layer(Eg: "Walls") and fillet them with (0.25) radius .I am just new at this lisp scene so any help would be appreciated.Below is the separate code that selects all elements of layer and  another code fillets all selected polylines.How can i combine these two to create a single lisp for certain layer("walls") and (0.25) fillet.
(defun c:SALL ()
 (setq TargEnt (car (entsel "\nSelect object on layer to select: ")))
 (setq TargLayer (assoc 8 (entget TargEnt)))
 (sssetfirst nil (ssget "_X" (list TargLayer)))
(defun C:FMP ; = Fillet Multiple Polylines
  (/ plss n)
  (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE"))))
    (repeat (setq n (sslength plss))
      (command "_.fillet" "_polyline" (ssname plss (setq n (1- n))))
    ); repeat
  ); if
); defun
HOSNEYALAA
Re: How to select all polylines of certain layer and fillet them !!
« Reply #1 on: September 22, 2020, 03:31:32 AM »
For better understanding, and, maybe, get further help, please upload such sample.dwg
As far as I know, ACAD only can edit DWG.
JohnCamper
  • Mosquito
« Reply #2 on: September 22, 2020, 04:11:01 AM »
As in the picture i want all the polylines with layer name "wall" to be filleted with radius 0.25.
Dlanor
« Reply #3 on: September 22, 2020, 04:11:38 AM »
Are you trying to automatically fillet ALL lwpolylines on the layer or only the selected ones? What CAD are you using on which platform?
JohnCamper
  • Mosquito
« Reply #4 on: September 22, 2020, 04:17:07 AM »
Yes,I want to fillet ALL lwpolylines on the layer named "wall".The 2nd code that i have put will fillet the selected polylines with previous settings.
I use windows and Autocad 2020.
Tharwat
  • Hypersensitive
« Reply #5 on: September 22, 2020, 04:57:38 AM »
  1. (defun c:Test ( / int sel ent)
  2.   (and (setq int -1 sel (ssget "_:L" '((0 . "LWPOLYLINE"))))
  3.      (while (setq int (1+ int) ent (ssname sel int))
  4.        (command "_.FILLET" "_Polyline" ent)
  5.        )
  6.      )
  7. )
JohnCamper
  • Mosquito
« Reply #6 on: September 22, 2020, 05:13:47 AM »
@Tharwat Thank you for posting but the lisp code that you have posted does the same thing as the lisp code that i have posted above !
I want to Fillet(with radius:0.25) all the polylines under layer "wall .No need to select the lines.Just run the lisp and it does the thing.
Tharwat
  • Hypersensitive
« Reply #7 on: September 22, 2020, 05:24:28 AM »
Alright, here you go.
  1. (defun c:Test (/ int sel ent)
  2.   (and
  3.     (or (/= 4
  4.             (logand 4
  5.                     (cdr (assoc 70 (entget (tblobjname "LAYER" "wall"))))
  6.             )
  7.         )
  8.         (alert "Layer name <wall> is locked ! unlock then try again"
  9.         )
  10.     )
  11.     (setq int -1
  12.           sel (ssget "_X"
  13.                      (list '(0 . "LWPOLYLINE")
  14.                            '(8 . "wall")
  15.                            (cons 410 (getvar 'CTAB))
  16.                      )
  17.               )
  18.     )
  19.     (setvar 'FILLETRAD 0.25)
  20.     (while (setq int (1+ int)
  21.                  ent (ssname sel int)
  22.            )
  23.       (command "_.FILLET" "_Polyline" ent)
  24.     )
  25.   )
  26.   (princ)
  27. )
JohnCamper
  • Mosquito
« Reply #8 on: September 22, 2020, 05:44:21 AM »
Thank you so much @Tharwat.It worked as expected !!  :-)
Tharwat
  • Hypersensitive
« Reply #9 on: September 22, 2020, 05:46:13 AM »
You're welcome anytime.
