Author Topic: Sheet Index  (Read 7784 times)
cmwade77
Sheet Index
« on: September 15, 2020, 02:46:36 PM »
Is there a way to use LISP to add a Sheet Index from the Sheet Set Manager? I have been starting to look around, but haven't found much so far.
HOSNEYALAA
Re: Sheet Index
« Reply #1 on: September 15, 2020, 04:49:56 PM »
Sheet Index IN EXCEL
OR
NO
cmwade77
Re: Sheet Index
« Reply #2 on: September 15, 2020, 04:56:21 PM »
No, just the standard right click on the sheets and select insert sheet index, but a lisp equivalent.
Tharwat
  • Hypersensitive
Re: Sheet Index
« Reply #3 on: September 15, 2020, 05:23:58 PM »
AutoLISP has no access to SSM so you need to use any of the .NET programming languages.
BIGAL
  • 40 + years of using Autocad
Re: Sheet Index
« Reply #4 on: September 15, 2020, 07:59:34 PM »
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/sheet-set-manager-macros/td-p/7191248
Pretty sure have seen write a dst file elsewhere not something I have done.
« Last Edit: September 15, 2020, 08:02:59 PM by BIGAL »
Re: Sheet Index
« Reply #5 on: September 15, 2020, 08:45:31 PM »
cmwade77
Re: Sheet Index
« Reply #6 on: September 16, 2020, 12:08:27 PM »
If you get bored there’s this little thang, cheers.
Yeah, there is that one (I have used it as a base for another tool I use), I can always roll my own version I suppose, but I was trying to avoid that.....LOL
framednlv
Re: Sheet Index
« Reply #7 on: September 16, 2020, 12:35:53 PM »
I was able to setup a sheet set file, wblock the sheet index and import it into another project.  When you bring in the block you have to set it to explode when inserting (not after).  After you bring it in, you have to edit the sheetset table to use the current sheet set.
cmwade77
Re: Sheet Index
« Reply #8 on: September 16, 2020, 12:38:28 PM »
I followed you right up to the last bit, how do you modify it to use the current sheet set?
framednlv
Re: Sheet Index
« Reply #9 on: September 16, 2020, 12:47:07 PM »
Click on the first cell, not in it.  Right click->Sheet List Table->Edit Sheet List Table Settings...
Then in the Sheet List Table click on the Subsets and Sheets tab.  You then select from there.
framednlv
Re: Sheet Index
« Reply #10 on: September 16, 2020, 12:50:19 PM »
This is something that I have not found in any of the forums.  It only took about 10 years of using Sheet Sets to figure this out.
cmwade77
Re: Sheet Index
« Reply #11 on: September 16, 2020, 12:59:13 PM »
Interesting, now can we find a way to edit it in LISP?
framednlv
Re: Sheet Index
« Reply #12 on: September 16, 2020, 01:02:24 PM »
Did you get it to work?
cmwade77
Re: Sheet Index
« Reply #13 on: September 17, 2020, 07:31:24 PM »
Unfortunately, this pesky little thing called work got in the way.   :2funny:
alanjt
  • Standby for witty remark...
Re: Sheet Index
« Reply #14 on: September 18, 2020, 11:32:34 AM »
I can only get the option to display in the right-click menu if I click inside the cell, and even then, it will not let me make changes.
This is incredible, Michael.
« Last Edit: September 18, 2020, 11:36:58 AM by alanjt »
Dropbox
