Author Topic: Sheet Index  (Read 7764 times)
cmwade77
Sheet Index
« on: September 15, 2020, 02:46:36 PM »
Is there a way to use LISP to add a Sheet Index from the Sheet Set Manager? I have been starting to look around, but haven't found much so far.
HOSNEYALAA
Re: Sheet Index
« Reply #1 on: September 15, 2020, 04:49:56 PM »
Sheet Index IN EXCEL
OR
NO
cmwade77
Re: Sheet Index
« Reply #2 on: September 15, 2020, 04:56:21 PM »
No, just the standard right click on the sheets and select insert sheet index, but a lisp equivalent.
Tharwat
  • Hypersensitive
Re: Sheet Index
« Reply #3 on: September 15, 2020, 05:23:58 PM »
AutoLISP has no access to SSM so you need to use any of the .NET programming languages.
BIGAL
  • 40 + years of using Autocad
Re: Sheet Index
« Reply #4 on: September 15, 2020, 07:59:34 PM »
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/sheet-set-manager-macros/td-p/7191248
Pretty sure have seen write a dst file elsewhere not something I have done.
« Last Edit: September 15, 2020, 08:02:59 PM by BIGAL »
Re: Sheet Index
« Reply #5 on: September 15, 2020, 08:45:31 PM »
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
cmwade77
Re: Sheet Index
« Reply #6 on: September 16, 2020, 12:08:27 PM »
If you get bored there’s this little thang, cheers.
Yeah, there is that one (I have used it as a base for another tool I use), I can always roll my own version I suppose, but I was trying to avoid that.....LOL
framednlv
Re: Sheet Index
« Reply #7 on: September 16, 2020, 12:35:53 PM »
I was able to setup a sheet set file, wblock the sheet index and import it into another project.  When you bring in the block you have to set it to explode when inserting (not after).  After you bring it in, you have to edit the sheetset table to use the current sheet set.
cmwade77
Re: Sheet Index
« Reply #8 on: September 16, 2020, 12:38:28 PM »
I followed you right up to the last bit, how do you modify it to use the current sheet set?
framednlv
Re: Sheet Index
« Reply #9 on: September 16, 2020, 12:47:07 PM »
Click on the first cell, not in it.  Right click->Sheet List Table->Edit Sheet List Table Settings...
Then in the Sheet List Table click on the Subsets and Sheets tab.  You then select from there.
framednlv
Re: Sheet Index
« Reply #10 on: September 16, 2020, 12:50:19 PM »
This is something that I have not found in any of the forums.  It only took about 10 years of using Sheet Sets to figure this out.
cmwade77
Re: Sheet Index
« Reply #11 on: September 16, 2020, 12:59:13 PM »
Interesting, now can we find a way to edit it in LISP?
framednlv
Re: Sheet Index
« Reply #12 on: September 16, 2020, 01:02:24 PM »
Did you get it to work?
cmwade77
Re: Sheet Index
« Reply #13 on: September 17, 2020, 07:31:24 PM »
Unfortunately, this pesky little thing called work got in the way.   :2funny:
alanjt
  • Standby for witty remark...
Re: Sheet Index
« Reply #14 on: September 18, 2020, 11:32:34 AM »
I can only get the option to display in the right-click menu if I click inside the cell, and even then, it will not let me make changes.
This is incredible, Michael.
« Last Edit: September 18, 2020, 11:36:58 AM by alanjt »
Dropbox
Re: Sheet Index
« Reply #15 on: September 18, 2020, 12:13:54 PM »
Nice! You're too kind Alan.
Much of it was merely the translation of other's fine work (GILESP, Jeff H and JAR).
All of it was highly enjoyable, nerdy fun. :)
cmwade77
Re: Sheet Index
« Reply #16 on: September 18, 2020, 12:44:47 PM »
Yeah, well, I was able to adapt it into a project I have written in XOJO for publishing PDFs, doing etransmits and such. It really is an incredible piece of work. I may indeed be using it to do what I am trying to accomplish here. I just need to figure out a way to determine what sheet set is being used by the open file.
Re: Sheet Index
« Reply #17 on: September 18, 2020, 01:26:23 PM »
It's music to hear a post helped out a fellow forumite. Thanks for sharing. 8-)
Keep digging, it's there somewhere -- it always is. :-)
cmwade77
Re: Sheet Index
« Reply #18 on: September 18, 2020, 02:46:47 PM »
The tool is very, very preliminary and I believe it had the credit for your code (I have since started a complete redesign of the tool for various reasons unrelated to your code), but I had posted it here:
http://www.theswamp.org/index.php?topic=54482.msg589986#msg589986
And I know it has to be there somewhere, otherwise how does AutoCAD know what sheetset to autoopen?
« Last Edit: September 18, 2020, 03:03:53 PM by cmwade77 »
Re: Sheet Index
« Reply #19 on: September 18, 2020, 03:09:05 PM »
If I had to hazard a guess it would be to ...
    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (vl-catch-all-apply 'eval '((setq dic (vla-item (vla-get-dictionaries doc) "AcSheetSetData"))))
    (if dic
            (princ "\nHouston we may have lift off ...")
            ;;  miracle code to follow ...
But that's just me.  :-)
cmwade77
Re: Sheet Index
« Reply #20 on: September 18, 2020, 04:09:14 PM »
    (if dic
Yeah, that tells me there is a Sheet Set associated to the layout, but what I need to know is what DST File (including path) I need to open. Yeah, I can do it the hard way and poke around the folder structure, but there has to be a better way.
Re: Sheet Index
« Reply #21 on: September 18, 2020, 04:57:05 PM »
I must be missing something. Bare bones code sans error trapping yada ...
(cdr
    (assoc 1
        (entget
            (vlax-vla-object->ename
                (vla-item
                    (vla-item
                        "AcSheetSetData"
                    "ShSetFileName"
>> "C:\\Program Files\\Autodesk\\AutoCAD 2019\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst"
cmwade77
Re: Sheet Index
« Reply #22 on: September 18, 2020, 05:03:48 PM »
(cdr
    (assoc 1
        (entget
                (vla-item
                    (vla-item
                        "AcSheetSetData"
                    "ShSetFileName"
Awesome, that should get me started.
framednlv
Re: Sheet Index
« Reply #23 on: September 21, 2020, 11:45:03 AM »
(getvar 'ssfound)
Re: Sheet Index
« Reply #24 on: September 21, 2020, 12:49:56 PM »
Assume find -- hadn't considered Autodesk would actually make something easy.  :-D
framednlv
Re: Sheet Index
« Reply #25 on: September 21, 2020, 12:53:04 PM »
The 'ssfound only applies if the sheet set file is open in the Sheet Set Manager.
cmwade77
Re: Sheet Index
« Reply #26 on: September 21, 2020, 01:15:31 PM »
Well, that is good to know, this is going to be an interesting one for me, because I just figured out that stealing what I already have written with LISP will result in much easier and more reliable programming. So, all of this information is going to be quite useful, thank you all.
steve.carson
Re: Sheet Index
« Reply #27 on: September 25, 2020, 12:05:20 PM »
Using the great code by MP for the DST->XML functions, by Lee Mac for the Table and DCL functions, and J. Szewczak for the XML functions, I put together the attached sheetset functions, some more useful than others. I'm sure anything written by me could be improved. I think this was the second time I played with DCL, so there was a lot of guess-and-check going on.
I think the most useful function in here is the "sstable" function that lets you create a regular autocad table from multiple dst files. This is handy for when you have separate dst's for each discipline in a project. I tried to mimic the built in method to create a sheet list table from the SSM, where you can specify the column headings for whatever property you want in the table. It stores an xrecord in the drawing, and uses it as defaults for the next time you run it. It's not very fast, but much faster than built in methods. Our projects are pretty big (Ports and Harbors, Marine structures).
There is also a function to index a sheet property ("indexss"), which is handy for the X in "sheet X of XX".
Hope for can find it useful!
Big thanks to MP, Lee Mac, and J. Szewczak!
Steve
steve.carson
Re: Sheet Index
« Reply #28 on: September 25, 2020, 12:09:32 PM »
Oh, yeah, forgot to mention there is always an error displayed at the command line when running the sstable function. I was never able to track it down, but it runs and completes and creates the table.
Steve
cmwade77
Re: Sheet Index
« Reply #29 on: October 07, 2020, 05:54:11 PM »
Ok, so I know this is a long shot, but maybe MP or someone else can help me out with this. I am currently writing this in XOJO, I have the routine down for decoding the DST file, but for some reason, encoding it back after I make edits doesn't work.
Here is what I have:
'Adapted from VBScript at: https://www.theswamp.org/index.php?topic=46497.msg573062#msg573062 and from LISP at: http://www.theswamp.org/index.php?topic=52362.0
Var Results As String
Var enc() As Integer = Array(0,1,2,3,4,5,6,7,10,11,12,13,14,15,16,17,20,21,22,23,24,25,26,27,30,31,32,33,34,35,36,37,40,41,42,43,44,45,46,47,50,51,52,53,54,55,56,57,60,61,62,63,64,65,66,67,70,71,72,73,74,75,76,77,100,101,102,103,104,105,106,107,110,111,112,113,114,115,116,117,120,121,122,123,124,125,126,127,130,131,132,133,134,135,136,137,140,141,142,143,144,145,146,147,150,151,152,153,154,155,156,157,160,161,162,163,164,165,166,167,170,171,172,173,174,175,176,177,200,201,202,203,204,205,206,207,210,211,212,213,214,215,216,217,220,221,222,223,224,225,226,227,230,231,232,233,234,235,236,237,240,241,242,243,244,245,246,247,250,251,252,253,254,255,256,257,260,261,262,263,264,265,266,267,270,271,272,273,274,275,276,277,300,301,302,303,304,305,306,307,310,311,312,313,314,315,316,317,320,321,322,323,324,325,326,327,330,331,332,333,334,335,336,337,340,341,342,343,344,345,346,347,350,351,352,353,354,355,356,357,360,361,362,363,364,365,366,367,370,371,372,373,374,375,376,377)
Var dec() As Integer = Array(214,213,216,215,210,207,212,211,204,203,206,205,200,177,202,201,174,173,176,175,170,167,172,171,164,163,166,165,160,157,162,161,254,253,256,255,250,247,252,251,244,243,246,245,240,237,242,241,234,233,236,235,230,227,232,231,224,223,226,225,220,217,222,221,314,313,316,315,310,307,312,311,304,303,306,305,300,277,302,301,274,273,276,275,270,267,272,271,264,263,266,265,260,257,262,261,354,353,356,355,350,347,352,351,344,343,346,345,340,337,342,341,334,333,336,335,330,327,332,331,324,323,326,325,320,317,322,321,14,13,16,15,10,7,12,11,4,3,6,5,0,377,2,1,374,373,376,375,370,367,372,371,364,363,366,365,360,357,362,361,54,53,56,55,50,47,52,51,44,43,46,45,40,37,42,41,34,33,36,35,30,27,32,31,24,23,26,25,20,17,22,21,114,113,116,115,110,107,112,111,104,103,106,105,100,77,102,101,74,73,76,75,70,67,72,71,64,63,66,65,60,57,62,61,154,153,156,155,150,147,152,151,144,143,146,145,140,137,142,141,134,133,136,135,130,127,132,131,124,123,126,125,120,117,122,121)
If Decode Then
  For x As Integer = 1 To fInfo.Length
    Var InChar As String = fInfo.Mid(x, 1)' Read character
    Var AChar As Integer = AscB(InChar)' Convert to AscII Character
    Var Con8Char As Integer = dec(AChar)' Read Character (in Octal) from array
    Var ConChar As String = Chr(Integer.FromOctal(Con8Char.ToText))'convert octal to integer
    If results = "" Then
      Results = ConChar
    Else
      Results = Results + ConChar
    End If
  Next x
Else
    Var A8Char As Integer = Oct(AChar).Val
    Var Pos As Integer = dec.IndexOf(A8Char)
    If pos > -1 And pos <= enc.LastRowIndex Then
      Var Con8Char As Integer = enc(pos)
        Results = ConChar
      Else
      End If
    End If
  Next x
End If
Return Results
NOTE: Integer.FromOctal is essentially the same as the EVAL function, but doesn't need &O at the beginning, but the number as to be converted to text.
I am sure I probably just have something out of place, but can't quite figure it out.
cmwade77
Re: Sheet Index
« Reply #30 on: October 07, 2020, 06:13:11 PM »
I have also tried:
If Decode Then
      Results = ConChar
    Else
    End If
  Next x
Else
  stdout.WriteLine(fInfo)
    For APos As Integer = 0 To dec.LastRowIndex
      If A8Char = Dec(APos) Then
        Con8Char = Enc(APos)
        Exit For APos
      End If
    Next
      Results = ConChar
    Else
    End If
  Next x
End If
Return Results
framednlv
Re: Sheet Index
« Reply #31 on: October 07, 2020, 07:09:39 PM »
I don't think you need to encode it.  If it is saved as regular text autocad will read it just fine.
cmwade77
Re: Sheet Index
« Reply #32 on: October 07, 2020, 08:02:32 PM »
So it would appear, the example provided above reencoded it, but why bother if this works? Perhaps someone has some logic why the examples have converting from XML to DST when a simple saveas should suffice? Just want to make sure I am not missing something.
cmwade77
Re: Sheet Index
« Reply #33 on: October 28, 2020, 07:03:08 PM »
(cdr
    (assoc 1
        (entget
                (vla-item
                    (vla-item
                        "AcSheetSetData"
                    "ShSetFileName"
Any chance you can help me figure out how to determine the Subset of the currently opened sheet? I would really appreciate it, I think there might just be a way within AutoCAD instead of my kludge method.
cmwade77
Re: Sheet Index
« Reply #34 on: April 06, 2022, 04:47:03 PM »
(cdr
    (assoc 1
        (entget
                (vla-item
                    (vla-item
                        "AcSheetSetData"
                    "ShSetFileName"
I added in a bit of error checking and figured I would put this here in case anyone else needs it:
; Code to determine the sheet index being used was adapted from: MP @ https://www.theswamp.org/index.php?topic=56246.msg601557#msg601557
(defun GetSheetIndex (/ *ThisDrawing* Obj_SheetSetData Obj_FileName Ent)
  (setq *ThisDrawing* (vla-get-activedocument (vlax-get-acad-object))
        *Dictionaries* (vla-get-dictionaries *ThisDrawing*)
  ;Need to check to see if Dictionaries contain AcSheetSetData
  (if (dictsearch (namedobjdict) "AcSheetSetData")
      (setq Obj_SheetSetData (vla-item *Dictionaries* "AcSheetSetData"))
      (if Obj_SheetSetData
          (setq Obj_FileName (vla-item Obj_SheetSetData "ShSetFileName"))
          (if Obj_FileName
              (setq Ent (entget (vlax-vla-object->ename Obj_FileName))
                    Results (cdr (assoc 1 Ent))
    (alert "No Dictionary")
  Results
);End GetSheetIndex
