Author Topic: Can not delete LEVEL 10  (Read 2191 times)
notredave
« on: September 14, 2020, 10:18:26 AM »
Good morning all,
Please see attached drawing. I edited block with BE. I changed all of my yellow test to layer text but when I use enhanced attribute editor, under properties, it still shows it on LEVEL 10. I want all yellow text on layer TEXT so I can purge LEVEL 10 but it's not working. Can someone take a look at drawing and let me know what the problem is? I would appreciate it.
Thank you,
Dave
Re: Can not delete LEVEL 10
« Reply #1 on: September 14, 2020, 11:12:40 AM »
Use ATTSYNC, select the block, purge the layer.  Since you changed the layer of the attributes, you need to Sync the references to match the new properties.
notredave
« Reply #2 on: September 14, 2020, 11:17:25 AM »
That did the trick Jeff_M. Thank you very much.
dgorsman
« Reply #3 on: September 14, 2020, 12:58:09 PM »
I always recommend users 'send up the Bat Signal' when manipulating attributes.  Gotta call BATTMAN to get the job done right.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
notredave
« Reply #4 on: September 14, 2020, 01:04:19 PM »
Thank you for that bit of info dgorsman.
