Author Topic: Grid point list conversion  (Read 7825 times)
wizman
Re: Grid point list conversion
« Reply #15 on: September 12, 2020, 12:32:35 PM »
Here's a rusty attempt:
(defun foo (a)
  (list
    (car a)
    (cadr a)
(defun rec (w / y)
  (if (cdadr w)
      (Setq y (foo w)
    z (cons (mapcar 'foo y)
    z
      (rec (mapcar 'cdr y))
      (rec (cdr w))
(defun rec2 (x / z)
  (rec x)
  (reverse
    (mapcar '(lambda (x)
       (apply 'append x)
    z
(rec2 '(
("1-1" "1-2" "1-3" "1-4" "1-5" "1-6" "1-7")
("2-1" "2-2" "2-3" "2-4" "2-5" "2-6" "2-7")
("3-1" "3-2" "3-3" "3-4" "3-5" "3-6" "3-7")
("4-1" "4-2" "4-3" "4-4" "4-5" "4-6" "4-7")
« Reply #16 on: September 14, 2020, 12:41:07 PM »
Benchmarks
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s):
    (SQUARE L).......1921 / 8.52 <fastest>
    (_RJPFOO L)......2094 / 7.81
    (F_BRUNO L)......2984 / 5.48
    (F L)............3141 / 5.21
    (REC2 L)........13516 / 1.21
    (SUBFOO L)......16359 / 1.00 <slowest>
« Reply #17 on: September 14, 2020, 01:44:09 PM »
awesome
ribarm
  • Marko Ribar, architect
« Reply #18 on: September 14, 2020, 02:24:21 PM »
I would say just "some" - on Serbian... OP haven't replied in any way saying thanks or something equal to anyone participated... I don't know are replies useful to him, but IMHO not reacting to request proposed in first post is humiliating behaviour for all that wanted to contribute... And timings of sub functions - benchmarking for this task are the least meaningful. I'd say that for a matrix 1000x1000 for normal PC it would take around 1 sec for computation with any of proposed subs... And 1000x1000 matrix is IMHO monkey bussines for any kind of situation OP may be facing in real life situation.
M.R. on Youtube
« Reply #19 on: September 14, 2020, 06:06:20 PM »
... OP haven't replied in any way saying thanks or something equal to anyone participated... I don't know are replies useful to him, but IMHO not reacting to request proposed in first post is humiliating behaviour for all that wanted to contribute ...
I don't feel humiliated but I'm assuming the OP may be engaged with matters of greater importance which could be family, job ... given his tenure here that seems probable.
Cheers.
VovKa
  • Ukraine
« Reply #20 on: September 15, 2020, 06:37:10 AM »
Benchmarks
benchmarking is tricky  :angel:
loaded from VLIDE
_$ (benchmark '((subfoo lst) (_rjpfoo lst) (f lst) (square lst) (fbru lst) (recrib lst)))
    (SQUARE LST)........1701 / 78.48 <fastest>
    (_RJPFOO LST).......2121 / 62.94
    (FBRU LST)..........2356 / 56.66
    (F LST).............2465 / 54.15
    (SUBFOO LST)........9703 / 13.76
    (RECRIB LST)......133491 / 1 <slowest>
LSP loaded from Autocad command line
Command: (load "D:\\Temp\\tmp1.lsp")
    (_RJPFOO LST).......1763 / 67.88 <fastest>
    (SQUARE LST)........2247 / 53.26
    (FBRU LST)..........3510 / 34.09
    (F LST).............3807 / 31.43
    (SUBFOO LST).......18876 / 6.34
    (RECRIB LST)......119668 / 1 <slowest>
FAS loaded from Autocad command line
Command: (load "D:\\Temp\\tmp1.fas")
    (_RJPFOO LST).......1077 / 125.05 <fastest>
    (FBRU LST)..........3495 / 38.53
    (F LST).............3807 / 35.38
    (SQUARE LST)........3807 / 35.38
    (SUBFOO LST).......18564 / 7.25
    (RECRIB LST)......134676 / 1 <slowest>
« Reply #21 on: September 15, 2020, 12:54:02 PM »
Benchmarks
loaded from VLIDE
That it is :) ... I like your numbers better   :2funny:
CodeDing
« Reply #22 on: September 15, 2020, 02:24:40 PM »
I know I'm a bit late to this party but it was fun to try. so I'll post anyways.
I mainly wanted to try to create without using append.
(defun map2sqr (map / squares)
  (mapcar
    '(lambda (m1 m2)
      (mapcar
        '(lambda (c1 c2 c3 c4)
          (setq squares (cons (list c1 c2 c3 c4) squares))
        );lambda
        m1
        (cdr m1)
        m2
        (cdr m2)
      );mapcar
    );lambda
    map
    (cdr map)
  );mapcar
  (reverse squares)
);defun
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
ribarm
« Reply #23 on: September 16, 2020, 07:33:25 AM »
Just to prove that benchmark for this task is wrong idea, here are results on my PC. :
  1. (defun c:recunfoldmatrix ( / matrix-n-m rec n m ti )
  2.
  3.   (defun matrix-n-m ( n m / nn mm itm row mat )
  4.     (setq nn 0)
  5.     (repeat n
  6.       (setq nn (1+ nn) mm 0)
  7.       (repeat m
  8.         (setq mm (1+ mm))
  9.         (setq itm (strcat (itoa nn) "-" (itoa mm)))
  10.         (setq row (cons itm row))
  11.       )
  12.       (setq mat (cons (reverse row) mat) row nil)
  13.     )
  14.     (reverse mat)
  15.   )
  16.
  17.   (defun rec ( mat / k itm1 itm2 kk lst )
  18.     (setq k -1)
  19.     (repeat (length mat)
  20.       (setq k (1+ k))
  21.       (setq itm1
  22.         (vl-remove-if-not '(lambda ( x ) (= (length x) 2))
  23.           (mapcar '(lambda ( x ) (setq kk (if (null kk) 2 (1+ kk))) (vl-remove-if-not '(lambda ( y ) (< (- kk 3) (vl-position y (nth k mat)) kk)) (nth k mat))) (nth k mat))
  24.         )
  25.       )
  26.       (setq kk nil)
  27.       (setq itm2
  28.         (vl-remove-if-not '(lambda ( x ) (= (length x) 2))
  29.           (mapcar '(lambda ( x ) (setq kk (if (null kk) 2 (1+ kk))) (vl-remove-if-not '(lambda ( y ) (< (- kk 3) (vl-position y (nth (1+ k) mat)) kk)) (nth (1+ k) mat))) (nth (1+ k) mat))
  30.         )
  31.       )
  32.       (setq kk nil)
  33.       (setq itm (mapcar '(lambda ( a b ) (append a b)) itm1 itm2))
  34.       (setq lst (cons itm lst))
  35.     )
  36.     (apply 'append (reverse lst))
  37.   )
  38.
  39.   (initget 7)
  40.   (setq n (getint "\nSpecify number of rows of matrix : "))
  41.   (initget 7)
  42.   (setq m (getint "\nSpecify number of columns of matrix : "))
  43.   (setq ti (car (_vl-times)))
  44.   (princ "\n")
  45.   (prin1 (rec (matrix-n-m n m)))
  46.   (princ "\n")
  47.   (prompt "\nElapsed time : ") (princ (rtos (- (car (_vl-times)) ti) 2 20)) (prompt " milliseconds...")
  48.   (princ)
  49. )
  50.
  51. ;|
  52. Command: RECUNFOLDMATRIX
  53.
  54. Specify number of rows of matrix : 50
  55.
  56. Specify number of columns of matrix : 50
  57.
  58. (("1-1" "1-2" "2-1" "2-2") ("1-2" "1-3" "2-2" "2-3") ("1-3" "1-4" "2-3" "2-4") ("1-4" "1-5" "2-4" "2-5") ("1-5" "1-6" "2-5" "2-6") ("1-6" "1-7" "2-6" "2-7") ("1-7" "1-8" "2-7" "2-8") ("1-8" "1-9" "2-8" "2-9") ("1-9" "1-10" "2-9" "2-10") ("1-10" "1-11" "2-10" "2-11") ("1-11" "1-12" "2-11" "2-12") ("1-12" "1-13" "2-12" "2-13") ("1-13" "1-14" "2-13" "2-14") ("1-14" "1-15" "2-14" "2-15") ("1-15" "1-16" "2-15" "2-16") ("1-16" "1-17" "2-16" "2-17") ("1-17" "1-18" "2-17" "2-18") ("1-18" "1-19" "2-18" "2-19") ("1-19" "1-20" "2-19" "2-20") ("1-20" "1-21" "2-20" "2-21") ("1-21" "1-22" "2-21" "2-22") ("1-22" "1-23" "2-22" "2-23") ("1-23" "1-24" "2-23" "2-24") ("1-24" "1-25" "2-24" "2-25") ("1-25" "1-26" "2-25" "2-26") ("1-26" "1-27" "2-26" "2-27") ("1-27" "1-28" "2-27" "2-28") ("1-28" "1-29" "2-28" "2-29") ("1-29" "1-30" "2-29" "2-30") ("1-30" "1-31" "2-30" "2-31") ("1-31" "1-32" "2-31" "2-32") ("1-32" "1-33" "2-32" "2-33") ("1-33" "1-34" "2-33" "2-34") ("1-34" "1-35" "2-34" "2-35") ("1-35" "1-36" "2-35" "2-36") ("1-36" "1-37" "2-36" "2-37") ("1-37" "1-38" "2-37" "2-38") ("1-38" "1-39" "2-38" "2-39") ("1-39" "1-40" "2-39" "2-40") ("1-40" "1-41" "2-40" "2-41") ("1-41" "1-42" "2-41" "2-42") ("1-42" "1-43" "2-42" "2-43") ("1-43" "1-44" "2-43" "2-44") ("1-44" "1-45" "2-44" "2-45") ("1-45" "1-46" "2-45" "2-46") ("1-46" "1-47" "2-46" "2-47") ("1-47" "1-48" "2-47" "2-48") ("1-48" "1-49" "2-48" "2-49") ("1-49" "1-50" "2-49" "2-50")
  59.
  60. ...
  61.
  62. ("49-1" "49-2" "50-1" "50-2") ("49-2" "49-3" "50-2" "50-3") ("49-3" "49-4" "50-3" "50-4") ("49-4" "49-5" "50-4" "50-5") ("49-5" "49-6" "50-5" "50-6") ("49-6" "49-7" "50-6" "50-7") ("49-7" "49-8" "50-7" "50-8") ("49-8" "49-9" "50-8" "50-9") ("49-9" "49-10" "50-9" "50-10") ("49-10" "49-11" "50-10" "50-11") ("49-11" "49-12" "50-11" "50-12") ("49-12" "49-13" "50-12" "50-13") ("49-13" "49-14" "50-13" "50-14") ("49-14" "49-15" "50-14" "50-15") ("49-15" "49-16" "50-15" "50-16") ("49-16" "49-17" "50-16" "50-17") ("49-17" "49-18" "50-17" "50-18") ("49-18" "49-19" "50-18" "50-19") ("49-19" "49-20" "50-19" "50-20") ("49-20" "49-21" "50-20" "50-21") ("49-21" "49-22" "50-21" "50-22") ("49-22" "49-23" "50-22" "50-23") ("49-23" "49-24" "50-23" "50-24") ("49-24" "49-25" "50-24" "50-25") ("49-25" "49-26" "50-25" "50-26") ("49-26" "49-27" "50-26" "50-27") ("49-27" "49-28" "50-27" "50-28") ("49-28" "49-29" "50-28" "50-29") ("49-29" "49-30" "50-29" "50-30") ("49-30" "49-31" "50-30" "50-31") ("49-31" "49-32" "50-31" "50-32") ("49-32" "49-33" "50-32" "50-33") ("49-33" "49-34" "50-33" "50-34") ("49-34" "49-35" "50-34" "50-35") ("49-35" "49-36" "50-35" "50-36
  63. ") ("49-36" "49-37" "50-36" "50-37") ("49-37" "49-38" "50-37" "50-38") ("49-38" "49-39" "50-38" "50-39") ("49-39" "49-40" "50-39" "50-40") ("49-40" "49-41" "50-40" "50-41") ("49-41" "49-42" "50-41" "50-42") ("49-42" "49-43" "50-42" "50-43") ("49-43" "49-44" "50-43" "50-44") ("49-44" "49-45" "50-44" "50-45") ("49-45" "49-46" "50-45" "50-46") ("49-46" "49-47" "50-46" "50-47") ("49-47" "49-48" "50-47" "50-48") ("49-48" "49-49" "50-48" "50-49") ("49-49" "49-50" "50-49" "50-50"))
  64.
  65. Elapsed time : 1328.000000000000 milliseconds...
  66. |;
  67.
  68. ;;; Second test : Elapsed time : 1438.000000000000 milliseconds...
  69.
  1. (defun c:rjpfoounfoldmatrix ( / matrix-n-m rec n m ti )
  2.
  4.     (setq nn 0)
  5.     (repeat n
  7.       (repeat m
  11.       )
  13.     )
  14.     (reverse mat)
  15.   )
  16.
  17.   (defun _rjpfoo ( l / a b r )
  18.     (while (cadr l)
  19.       (setq a (car l)
  20.             b (cadr l)
  21.             l (cdr l)
  22.       )
  23.       (while (cadr a)
  24.         (setq r (cons (list (car a) (cadr a) (car b) (cadr b)) r)
  25.               a (cdr a)
  26.               b (cdr b)
  27.         )
  28.       )
  29.     )
  30.     (reverse r)
  31.   )
  32.
  33.   (initget 7)
  34.   (setq n (getint "\nSpecify number of rows of matrix : "))
  35.   (initget 7)
  36.   (setq m (getint "\nSpecify number of columns of matrix : "))
  37.   (setq ti (car (_vl-times)))
  38.   (princ "\n")
  39.   (prin1 (_rjpfoo (matrix-n-m n m)))
  40.   (princ "\n")
  41.   (prompt "\nElapsed time : ") (princ (rtos (- (car (_vl-times)) ti) 2 20)) (prompt " milliseconds...")
  42.   (princ)
  43. )
  44.
  45. ;|
  46. Command: RJPFOOUNFOLDMATRIX
  47.
  48. Specify number of rows of matrix : 50
  49.
  50. Specify number of columns of matrix : 50
  51.
  52. (("1-1" "1-2" "2-1" "2-2") ("1-2" "1-3" "2-2" "2-3") ("1-3" "1-4" "2-3" "2-4") ("1-4" "1-5" "2-4" "2-5") ("1-5" "1-6" "2-5" "2-6") ("1-6" "1-7" "2-6" "2-7") ("1-7" "1-8" "2-7" "2-8") ("1-8" "1-9" "2-8" "2-9") ("1-9" "1-10" "2-9" "2-10") ("1-10" "1-11" "2-10" "2-11") ("1-11" "1-12" "2-11" "2-12") ("1-12" "1-13" "2-12" "2-13") ("1-13" "1-14" "2-13" "2-14") ("1-14" "1-15" "2-14" "2-15") ("1-15" "1-16" "2-15" "2-16") ("1-16" "1-17" "2-16" "2-17") ("1-17" "1-18" "2-17" "2-18") ("1-18" "1-19" "2-18" "2-19") ("1-19" "1-20" "2-19" "2-20") ("1-20" "1-21" "2-20" "2-21") ("1-21" "1-22" "2-21" "2-22") ("1-22" "1-23" "2-22" "2-23") ("1-23" "1-24" "2-23" "2-24") ("1-24" "1-25" "2-24" "2-25") ("1-25" "1-26" "2-25" "2-26") ("1-26" "1-27" "2-26" "2-27") ("1-27" "1-28" "2-27" "2-28") ("1-28" "1-29" "2-28" "2-29") ("1-29" "1-30" "2-29" "2-30") ("1-30" "1-31" "2-30" "2-31") ("1-31" "1-32" "2-31" "2-32") ("1-32" "1-33" "2-32" "2-33") ("1-33" "1-34" "2-33" "2-34") ("1-34" "1-35" "2-34" "2-35") ("1-35" "1-36" "2-35" "2-36") ("1-36" "1-37" "2-36" "2-37") ("1-37" "1-38" "2-37" "2-38") ("1-38" "1-39" "2-38" "2-39") ("1-39" "1-40" "2-39" "2-40") ("1-40" "1-41" "2-40" "2-41") ("1-41" "1-42" "2-41" "2-42") ("1-42" "1-43" "2-42" "2-43") ("1-43" "1-44" "2-43" "2-44") ("1-44" "1-45" "2-44" "2-45") ("1-45" "1-46" "2-45" "2-46") ("1-46" "1-47" "2-46" "2-47") ("1-47" "1-48" "2-47" "2-48") ("1-48" "1-49" "2-48" "2-49") ("1-49" "1-50" "2-49" "2-50")
  53.
  54. ...
  55.
  56. ("49-1" "49-2" "50-1" "50-2") ("49-2" "49-3" "50-2" "50-3") ("49-3" "49-4" "50-3" "50-4") ("49-4" "49-5" "50-4" "50-5") ("49-5" "49-6" "50-5" "50-6") ("49-6" "49-7" "50-6" "50-7") ("49-7" "49-8" "50-7" "50-8") ("49-8" "49-9" "50-8" "50-9") ("49-9" "49-10" "50-9" "50-10") ("49-10" "49-11" "50-10" "50-11") ("49-11" "49-12" "50-11" "50-12") ("49-12" "49-13" "50-12" "50-13") ("49-13" "49-14" "50-13" "50-14") ("49-14" "49-15" "50-14" "50-15") ("49-15" "49-16" "50-15" "50-16") ("49-16" "49-17" "50-16" "50-17") ("49-17" "49-18" "50-17" "50-18") ("49-18" "49-19" "50-18" "50-19") ("49-19" "49-20" "50-19" "50-20") ("49-20" "49-21" "50-20" "50-21") ("49-21" "49-22" "50-21" "50-22") ("49-22" "49-23" "50-22" "50-23") ("49-23" "49-24" "50-23" "50-24") ("49-24" "49-25" "50-24" "50-25") ("49-25" "49-26" "50-25" "50-26") ("49-26" "49-27" "50-26" "50-27") ("49-27" "49-28" "50-27" "50-28") ("49-28" "49-29" "50-28" "50-29") ("49-29" "49-30" "50-29" "50-30") ("49-30" "49-31" "50-30" "50-31") ("49-31" "49-32" "50-31" "50-32") ("49-32" "49-33" "50-32" "50-33") ("49-33" "49-34" "50-33" "50-34") ("49-34" "49-35" "50-34" "50-35") ("49-35" "49-36" "50-35" "50-36
  57. ") ("49-36" "49-37" "50-36" "50-37") ("49-37" "49-38" "50-37" "50-38") ("49-38" "49-39" "50-38" "50-39") ("49-39" "49-40" "50-39" "50-40") ("49-40" "49-41" "50-40" "50-41") ("49-41" "49-42" "50-41" "50-42") ("49-42" "49-43" "50-42" "50-43") ("49-43" "49-44" "50-43" "50-44") ("49-44" "49-45" "50-44" "50-45") ("49-45" "49-46" "50-45" "50-46") ("49-46" "49-47" "50-46" "50-47") ("49-47" "49-48" "50-47" "50-48") ("49-48" "49-49" "50-48" "50-49") ("49-49" "49-50" "50-49" "50-50"))
  58.
  59. Elapsed time : 3047.000000000000 milliseconds...
  60. |;
  61.
  62. ;;; Second test : Elapsed time : 4735.000000000000 milliseconds...
  63.
As you can see, I was perhaps wrong for 1000x1000 matrix and 1 second, but my function is indeed faster than Ron's - testing sample done at 50x50 matrix... For spacing issues, I didn't copy+pasted all return list, but only first and last summing result...
M.R. on Youtube
VovKa
  • Ukraine
« Reply #24 on: September 16, 2020, 08:58:03 AM »
Marko, can you repeat the test without (prin1 ) ?
Stefan
  • The most I miss IRL is the Undo button
« Reply #25 on: September 16, 2020, 09:57:10 AM »
Marko, I think you take this challenge/benchmark too serious.
« Last Edit: September 16, 2020, 03:47:20 PM by Stefan »
Marc'Antonio Alessi
  • Marco
« Reply #26 on: September 16, 2020, 11:29:24 AM »
I agree with "benchmarking is tricky  :angel:", I wanted to add that it can also vary with the CAD software. Perhaps the "Bruno_F" function is worthy of evaluation ...
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
BricsCAD V20
Elapsed milliseconds / relative speed for 524288 iteration(s):
    (BRUNO_F MLIST)......1109 / 49.51 <fastest>
    (SQUARE MLIST).......1359 / 40.4
    (VOVKA_F MLIST)......1812 / 30.3
    (_RJPFOO MLIST)......1828 / 30.04
    (MAP2SQR MLIST)......2469 / 22.24
    (SUBFOO MLIST).......5984 / 9.18
    (REC2 MLIST)........12266 / 4.48
    (MR_REC MLIST)......54906 / 1 <slowest>
    (BRUNO_F MLIST).....1313 / 2.04 <fastest>
    (SQUARE MLIST)......1359 / 1.97
    (_RJPFOO MLIST).....2000 / 1.34
    (VOVKA_F MLIST).....2078 / 1.29
    (MAP2SQR MLIST).....2672 / 1 <slowest>
    (BRUNO_F MLIST).....1109 / 1.65 <fastest>
    (SQUARE MLIST)......1140 / 1.6
    (VOVKA_F MLIST).....1812 / 1.01
    (_RJPFOO MLIST).....1828 / 1 <slowest>
    (BRUNO_F MLIST).....1266 / 1.06 <fastest>
    (SQUARE MLIST)......1344 / 1 <slowest>
AutoCAD 2013
    (_RJPFOO MLIST)......2438 / 31.63 <fastest>
    (BRUNO_F MLIST)......2766 / 27.88
    (MAP2SQR MLIST)......3031 / 25.45
    (SQUARE MLIST).......3859 / 19.99
    (VOVKA_F MLIST)......7312 / 10.55
    (REC2 MLIST)........28984 / 2.66
    (SUBFOO MLIST)......34016 / 2.27
    (MR_REC MLIST)......77125 / 1 <slowest>
    (_RJPFOO MLIST).....1125 / 2.35 <fastest>
    (BRUNO_F MLIST).....1219 / 2.17
    (MAP2SQR MLIST).....1468 / 1.8
    (SQUARE MLIST)......1469 / 1.8
    (VOVKA_F MLIST).....2641 / 1 <slowest>
    (_RJPFOO MLIST).....1047 / 1.39 <fastest>
    (BRUNO_F MLIST).....1203 / 1.21
    (SQUARE MLIST)......1422 / 1.02
    (MAP2SQR MLIST).....1453 / 1 <slowest>
    (_RJPFOO MLIST).....1094 / 1.2 <fastest>
    (BRUNO_F MLIST).....1313 / 1 <slowest>
« Reply #27 on: September 16, 2020, 11:58:01 AM »
  2.
  4.     (setq nn 0)
  5.     (repeat n
  7.       (repeat m
  11.       )
  13.     )
  14.     (reverse mat)
  15.   )
  16.
  18.     (setq k -1)
  20.       (setq k (1+ k))
  21.       (setq itm1
  24.         )
  25.       )
  26.       (setq kk nil)
  27.       (setq itm2
  30.         )
  31.       )
  32.       (setq kk nil)
  35.     )
  37.   )
  38.
  39.   (initget 7)
  41.   (initget 7)
  44.   (princ "\n")
  46.   (princ "\n")
  48.   (princ)
  49. )
  50.
  51. ;|
  53.
  55.
  57.
  59.
  60. ...
  61.
  64.
  66. |;
  67.
  69.
  2.
  4.     (setq nn 0)
  5.     (repeat n
  7.       (repeat m
  11.       )
  13.     )
  14.     (reverse mat)
  15.   )
  16.
  18.     (while (cadr l)
  19.       (setq a (car l)
  20.             b (cadr l)
  21.             l (cdr l)
  22.       )
  23.       (while (cadr a)
  25.               a (cdr a)
  26.               b (cdr b)
  27.         )
  28.       )
  29.     )
  30.     (reverse r)
  31.   )
  32.
  33.   (initget 7)
  35.   (initget 7)
  38.   (princ "\n")
  40.   (princ "\n")
  42.   (princ)
  43. )
  44.
  45. ;|
  47.
  49.
  51.
  53.
  54. ...
  55.
  58.
  60. |;
  61.
  63.
Strange .. when I run the test you created 'c:rjpfoounfoldmatrix' with 50x50 speed is waaay faster than what you posted (AutoCAD 2021)
Elapsed time : 234.0000000000000 milliseconds...
wizman
« Reply #28 on: September 16, 2020, 01:19:46 PM »
Thank you for benchmarking guys.
My nested recursion has failed in speed.  I can't even benchmark it along with your great codes.
Nonetheless, it is fun to solve and see everyone's creativity in approaching the problem.
VovKa
  • Ukraine
« Reply #29 on: September 16, 2020, 02:07:38 PM »
may i ask you the same thing, Ron?
https://www.theswamp.org/index.php?topic=56239.msg601499#msg601499
