Author Topic: Grid point list conversion  (Read 7812 times)
Re: Grid point list conversion
« Reply #30 on: September 16, 2020, 03:26:36 PM »
Strange .. when I run the test you created 'c:rjpfoounfoldmatrix' with 50x50 speed is waaay faster than what you posted (AutoCAD 2021)
Elapsed time : 234.0000000000000 milliseconds...
may i ask you the same thing, Ron?
https://www.theswamp.org/index.php?topic=56239.msg601499#msg601499
Sure :)
Command: RJPFOOUNFOLDMATRIX
Specify number of rows of matrix : 50
Specify number of columns of matrix : 50
Elapsed time : 16.00000000000000 milliseconds...
Command: RECUNFOLDMATRIX
Elapsed time : 1438.000000000000 milliseconds...
VovKa
  • Ukraine
« Reply #31 on: September 16, 2020, 06:22:41 PM »
Sure :)
That it is :) ... I like your numbers better   :2funny:
1+
VovKa
  • Ukraine
« Reply #32 on: September 16, 2020, 06:33:40 PM »
I wanted to add that it can also vary with the CAD software.
(BRUNO_F MLIST) is doing
524288 iterations for 1266 ms on Bricscad
and
32768 iterations for 1094 ms on Acad
looks like Bricscad is almost 14 times faster :)
cool
« Reply #33 on: September 16, 2020, 10:28:59 PM »
Awesome but I would have anticipated more. 🚀
Marc'Antonio Alessi
  • Marco
« Reply #34 on: September 17, 2020, 02:15:20 AM »
and
cool
AutoCAD 2021 t's even slower...
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (BRUNO_F MLIST).....1829 / 1.21 <fastest>
    (SQUARE MLIST)......2219 / 1 <slowest>
    (_RJPFOO MLIST).....1547 / 2.79 <fastest>
    (BRUNO_F MLIST).....1890 / 2.28
    (SQUARE MLIST)......2328 / 1.85
    (VOVKA_F MLIST).....4313 / 1 <slowest>
ribarm
  • Marko Ribar, architect
« Reply #35 on: September 17, 2020, 02:20:27 AM »
Considering results from my PC, I somehow don't believe to yours Ron... But IMHO, if OP would need matrix more than 50x50 elements I guess he is in nasty problems with his job... Around 1 second is very acceptable timing for a PC and this task... And like I said all proposed functions are good and suitable for this task and I agree with Stefan and his perception...
So my kudos go to Stefan 1+.
M.R. on Youtube
« Reply #36 on: September 17, 2020, 11:12:11 AM »
Yeah the numbers seem strange to me too but I'm just running the test you put together.  :wink:
Grrr1337
« Reply #37 on: September 17, 2020, 03:40:54 PM »
Thank you everyone for your contribution!
Indeed I was (and I'm still) busy in real life, agreed that it seems somewhat discrespectful for not replying on time.
Could've spent a few days figuring it out myself, but then I thought it may be better to post it here -
after all the task is related to a bit challenging list manipulation, while I knew I could rely on some of you.
Personally I don't get mad at the times when I provide a solution to an non-replying OP (like in this thread) rather just letting it sink in the web.
Surely I had the time to reply with just "thanks", which would seem more rude for me instead of non-replying -
because its like someone hands you a cigarette: while for a quick question it might be ok, for an algorithmic solution its not.
BTW I do code in my free time as an aside hobby (not making any $ out of it, but maybe as a part-time draughtsman - which is still not alot),
so not solving anything particular for a client - its more like a self-development thing.
My grid is max around 12x12, but we all agree that more and faster is better.
...nobody dropped the million dollar question for the potential usage of this sub.  :idea:
(apply ''((a b c)(a b c))
vevo.bg
wizman
« Reply #38 on: September 18, 2020, 01:44:03 AM »
Thank you for your response.
May i ask the application of this?  Do you need only 2x2 square?
Grrr1337
« Reply #39 on: September 18, 2020, 01:52:47 PM »
I was writing some distributed scattering...
vevo.bg
