Author Topic: Convert Layout to Block Definition  (Read 1513 times)
jtm2020hyo
« on: September 05, 2020, 09:43:16 AM »
Is there any AutoLisp than convert a Layout to Block and insert it to Model Space? I mean convert ViewPort to Xclip
Marco Jacinto
Re: Convert Layout to Block Definition
« Reply #1 on: September 05, 2020, 11:03:10 AM »
Maybe Layoutstodwgs is the command what you are looking for
PM
« Reply #2 on: September 05, 2020, 04:54:36 PM »
COMMAND CHSPACE . Convert Layout (paper space) to model space. Then you can convert it to block
jtm2020hyo
« Reply #3 on: September 05, 2020, 06:45:15 PM »
A great use of Layout conversion to Block Def and paste it to Model is something I call Plot to DWG, I mean the same feature than DWG to PDF, for the same motive CHSPACE and LAYOUTtoDWG is discarded.
I did a review for:
1 LayoutsToDwg
2 Layouts2Dwg
3 LXA
4 LXAv2
all of they are awesome for individual drawing with layouts, but:
1 and 2 just export the same drawing with a unique layout.
3 and 4  cut the plan but have problems with xclipped block reference and external references:
https://forums.autodesk.com/t5/autocad-forum/publish-layout-to-dwg/td-p/9565819
the main problem is to convert a viewport in xclip, for this motive si request for help, I did not found solution, so maybe a simple LISP for convert Layouts to Block defintion could solve this.
roy_043
  • BricsCAD 18
« Reply #4 on: September 06, 2020, 04:09:04 AM »
a simple LISP
What makes you think this would be a 'simple' Lisp function?
