Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
convert layers linetype
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: convert layers linetype (Read 1103 times)
PM
Guest
on:
September 04, 2020, 03:09:17 AM »
Hi i have a big list of layers and want to change all linetype to continuous by default. Is any lisp code for this?
Logged
Dlanor
Bull Frog
Re: convert layers linetype
Reply #1 on:
September 04, 2020, 06:52:42 AM »
Try this, it currently does all layers in the drawing but can be adapted inside the for loop to work with checking if the layer name is in a list.
Code - Auto/Visual Lisp:
[Select]
defun
c:l2c
doc
vl-load-com
vlax-for
lyr
vla-get-layers
setq
doc
vla-get-activedocument
vlax-get-acad-object
vlax-put
lyr 'linetype
"CONTINUOUS"
vlax-invoke
doc 'regen acallviewports
princ
Logged
Dlanor
http://www.theswamp.org/donate.html
PM
Guest
Reply #2 on:
September 04, 2020, 07:51:27 AM »
thank you Dlanor
Logged
Dlanor
Bull Frog
Reply #3 on:
September 04, 2020, 08:38:29 AM »
I've converted it to a function. Just pass the function a list of layer name and it will convert the linetypes of those layers to "CONTINUOUS" ie (rh:l2c layerlist)
[Select]
defun
rh:l2c
lst
doc
setq
lst
mapcar
strcase
lst
vlax-for
lyr
vla-get-layers
setq
doc
if
vl-position
strcase
vlax-get
lyr 'name
lst
vlax-put
lyr 'linetype
"CONTINUOUS"
vlax-invoke
Logged
Dlanor
Administrator
Seagull
Reply #4 on:
September 04, 2020, 08:56:11 AM »
Drive-by optimization.
Discussing your line #3.
[Select]
vlax-for
lyr
vla-get-layers
setq
doc
which creates a variable ("doc") each iteration of the loop and is VERY inefficient and slow.
Consider the following small, but efficient, bit of code as a template for you to consider.
[Select]
setq
acadobject
cond
acadobject
activedocument
cond
activedocument
acadobject
If you study this bit of code you can see the effency in it (hint: cond) which should lead you down the path of
[Select]
setq
acadobject
cond
acadobject
activedocument
cond
activedocument
acadobject
$lay
col$
cond
$lay
col$
vla-get-layers
activedocument
vlax-for
lyr $lay
col$ ...
EDIT: Fixed spelling error ("of").
Last Edit: September 04, 2020, 09:05:39 AM by John Kaul (Se7en)
Logged
TheSwamp.org
(serving the CAD community since 2003)
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
