Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: HATCHInvalid option keyword.; error: Function cancelled
You're welcome anytime.
(defun dfn_ent_layernew(resetlayer picksetListorStr / $rr mpl tip sos $rr ii elf mli) (setq;|a11476|; tip (type resetlayer) resetlayer (if (> resetlayer "") (strcase resetlayer T) nil)) (setq;|a11546|; $rr (if (> picksetListorStr "") (ssget "_X" (list (cons 0 picksetListorStr))) picksetListorStr)) (if (and $rr (not (tblsearch "LAYER" resetlayer))) (dfn_layer_new resetlayer 255 1 "")) (if (and $rr (tblsearch "LAYER" resetlayer)) (progn (progn (setq;|a11728|; ii (- (sslength $rr) 1)) (while (>= ii 0) (setq;|a11774|; elf (entget (ssname $rr ii)) mli (entmod (subst (cons 8 resetlayer) (assoc 8 elf) elf))) (setq;|a11894|; ii (- ii 1)))) (alert "okai"))) (princ) $rr)
