Author Topic: Automation error is prompted when using VLA-activate.Document switching is disab  (Read 1213 times)
iwill
  • Mosquito
Automation error is prompted when using VLA-activate.Document switching is disabled.Is there a system variable setting problem
(setq app (vlax-get-acad-object))
(setq docs (vla-get-documents app))
(setq doc (vla-item docs "yf.dwg"))
(vla-activate doc)
Crank
Look over here.
jbuzbee
      doc  (vla-item docs "X_Base.dwg")
(vla-activate doc)
Works for me
James Buzbee
Windows 8
