Author Topic: Folder Dialog Box  (Read 2388 times)
jtoverka
Folder Dialog Box
« on: August 25, 2020, 07:40:46 AM »
Hello all,
So I think we can all agree that the windows forms folder dialog search box is quite limiting. So I notice some newer programs like outlook have a considerably better dialog box. A picture of this is attached.
What Library has this dialog box?
badjo_5
  • Mosquito
Re: Folder Dialog Box
« Reply #2 on: August 26, 2020, 05:50:57 AM »
jtoverka
« Reply #3 on: August 26, 2020, 07:43:49 AM »
Try https://github.com/augustoproiete/ookii-dialogs-winforms or https://github.com/augustoproiete/ookii-dialogs-wpf, these are updated versions of http://www.ookii.org/software/dialogs/
I tried the wpf one first. Works like a charm and exactly what I wanted. Thank you very much.
CADbloke
  • Crash Test Dummy
« Reply #4 on: August 27, 2020, 05:03:39 AM »
Maybe this:
https://github.com/Willy-Kimura/BetterFolderBrowser
That one is interesting. Thanks for posting it. I have a use for that.
badjo_5
  • Mosquito
« Reply #5 on: August 27, 2020, 11:53:30 AM »
Or this:
using System;
using System.Reflection;
using System.Windows.Forms;
class OpenFolderDialog
        //public bool AddExtension { get; set; }
        public bool AutoUpgradeEnabled { get; set; }
        //public bool CheckFileExists { get; set; }
        public bool CheckPathExists { get; set; }
        //public bool DereferenceLinks { get; set; }
        public string Title { get; set; }
        //public string DefaultExt { get; set; }
        public string InitialDirectory { get; set; }
        //public bool ValidateNames { get; set; }
        //public bool SupportMultiDottedExtensions { get; set; }
        //public bool ShowHelp { get; set; }
        public bool Multiselect { get; set; }
        public bool RestoreDirectory { get; set; }
        //public string Filter { get; set; }
        public string SelectedPath { get; private set; }
        public string[] SelectedPaths { get; private set; }
        private FolderBrowserDialog FolderBrowser
            get
                return new FolderBrowserDialog()
                    ShowNewFolderButton = true,
                    Description = Title,
                    SelectedPath = InitialDirectory
        private OpenFileDialog Dialog
            get
                return new OpenFileDialog()
                    Title = Title,
                    AddExtension = false,
                    AutoUpgradeEnabled = AutoUpgradeEnabled,
                    CheckFileExists = true,
                    CheckPathExists = CheckPathExists,
                    DefaultExt = string.Empty,
                    DereferenceLinks = false,
                    InitialDirectory = InitialDirectory,
                    ValidateNames = false,
                    SupportMultiDottedExtensions = false,
                    ShowHelp = false,
                    Multiselect = Multiselect,
                    RestoreDirectory = RestoreDirectory,
                    Filter = string.Empty,
                    FileName = SelectedPath
        /// <param name="hWndOwner">Handle of the control or window to be the parent of the file dialog</param>
        /// <returns>true if the user clicks OK</returns>
        public DialogResult ShowDialog(IntPtr hWndOwner)
            if (Environment.OSVersion.Version.Major >= 6)
                OpenFileDialog dialog = Dialog;
                DialogResult result = VistaDialog.Show(hWndOwner, dialog) != 0 ? DialogResult.Cancel : DialogResult.OK;
                SelectedPath = dialog.FileName;
                SelectedPaths = dialog.FileNames;
                return result;
            else
                FolderBrowserDialog XPDialog = FolderBrowser;
                DialogResult result = XPDialog.ShowDialog();
                SelectedPath = XPDialog.SelectedPath;
                return result;
        private static class VistaDialog
            private const BindingFlags c_flags = BindingFlags.Instance | BindingFlags.Public | BindingFlags.NonPublic;
            private readonly static Assembly s_windowsFormsAssembly = typeof(FileDialog).Assembly;
            private readonly static Type s_iFileDialogType = s_windowsFormsAssembly.GetType("System.Windows.Forms.FileDialogNative+IFileDialog");
            private readonly static MethodInfo s_createVistaDialogMethodInfo = typeof(OpenFileDialog).GetMethod("CreateVistaDialog", c_flags);
            private readonly static MethodInfo s_onBeforeVistaDialogMethodInfo = typeof(OpenFileDialog).GetMethod("OnBeforeVistaDialog", c_flags);
            private readonly static MethodInfo s_getOptionsMethodInfo = typeof(FileDialog).GetMethod("GetOptions", c_flags);
            private readonly static MethodInfo s_setOptionsMethodInfo = s_iFileDialogType.GetMethod("SetOptions", c_flags);
            private readonly static uint s_fosPickFoldersBitFlag = (uint)s_windowsFormsAssembly
                .GetType("System.Windows.Forms.FileDialogNative+FOS")
                .GetField("FOS_PICKFOLDERS")
                .GetValue(null);
            private readonly static ConstructorInfo s_vistaDialogEventsConstructorInfo = s_windowsFormsAssembly
                .GetType("System.Windows.Forms.FileDialog+VistaDialogEvents")
                .GetConstructor(c_flags, null, new[] { typeof(FileDialog) }, null);
            private readonly static MethodInfo s_adviseMethodInfo = s_iFileDialogType.GetMethod("Advise");
            private readonly static MethodInfo s_unAdviseMethodInfo = s_iFileDialogType.GetMethod("Unadvise");
            private readonly static MethodInfo s_showMethodInfo = s_iFileDialogType.GetMethod("Show");
            public static int Show(IntPtr ownerHandle, OpenFileDialog dialog)
                var iFileDialog = s_createVistaDialogMethodInfo.Invoke(dialog, new object[] { });
                s_onBeforeVistaDialogMethodInfo.Invoke(dialog, new[] { iFileDialog });
                s_setOptionsMethodInfo.Invoke(iFileDialog, new object[] { (uint)s_getOptionsMethodInfo.Invoke(dialog, new object[] { }) | s_fosPickFoldersBitFlag });
                var adviseParametersWithOutputConnectionToken = new[] { s_vistaDialogEventsConstructorInfo.Invoke(new object[] { dialog }), 0U };
                s_adviseMethodInfo.Invoke(iFileDialog, adviseParametersWithOutputConnectionToken);
                try
                    return (int)s_showMethodInfo.Invoke(iFileDialog, new object[] { ownerHandle });
                finally
                    s_unAdviseMethodInfo.Invoke(iFileDialog, new[] { adviseParametersWithOutputConnectionToken[1] });
Example:
OpenFolderDialog folder = new OpenFolderDialog()
                Title = "Odaberi odredišnu mapu/folder",
                AutoUpgradeEnabled = true,
                CheckPathExists = true,
                InitialDirectory =
                    Environment.GetFolderPath
                    (Environment.SpecialFolder.DesktopDirectory),
                Multiselect = true,
                RestoreDirectory = true
            System.Windows.Forms.DialogResult result = folder.ShowDialog(IntPtr.Zero);
             if (result.Equals(System.Windows.Forms.DialogResult.OK))
                System.Windows.Forms.MessageBox.Show(folder.SelectedPath + " Paths:" + folder.SelectedPaths.Length);
