Author Topic: Adding polyline vertices in fixed intervals  (Read 2092 times)
Lupo76
« on: August 20, 2020, 11:45:29 AM »
I found this lisp which adds vertices along a polyline at a predetermined distance:
https://www.cadforum.cz/cadforum_en/adding-polyline-vertices-in-fixed-intervals-tip10091
It works fine if there are no edges, otherwise the result is incorrect :-(
Unfortunately on this occasion I don't have time to make a new lisp :embarrassed:
Do you have which lisp ready to do this?
Thanks in advance!
Lupo76
Re: Adding polyline vertices in fixed intervals
« Reply #1 on: August 21, 2020, 03:16:55 AM »
Sorry,
laziness seems like a bad disease that clouds the brain.
Here is the solution:
(defun c:demo2 ()
 (if (and (setq pline (car (entsel "\nSelect Polyline:")))
          (eq (cdr (assoc 0 (entget pline))) "LWPOLYLINE")
          (setq int (getdist "\nEnter Interval:"))
          (setq in int)
    (while (setq pt (vlax-curve-getPointAtDist pline int))
        (command "_break" pline pt pt)
        (command "_pedit" pline "_j" (entlast) "" "")
       (setq int (+ int in))
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: August 21, 2020, 11:55:08 PM »
Google pedit add vertice better than break and join.
xdcad
https://github.com/xdcad
http://bbs.xdcad.net
