Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
help with join dimension lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: help with join dimension lisp (Read 1274 times)
PM
Guest
on:
August 08, 2020, 12:57:43 PM »
Hi i find here
https://autocadtips1.com/2014/05/27/autolisp-updated-join-dimensions-for-autocad-2014-2015/
a lisp to join dimension. This code works fine but in my autocad the results is not corect because i use different agnle and direction units. Can any one fix it?
Code - Auto/Visual Lisp:
[Select]
;Shusei Hayashi
;OffshoreCad&Management Inc.
;10F Jaka Bldg., 6780 Ayala Ave.,
;Makati, Philippines
;http://www.offshorecad.com.ph/
;http://www.offshore-management.com.ph/
; Slightly modified to work with AutoCAD 2014 & 2015
; Greg Battin www.autocadtips.wordpress.com
defun
c:JDIMS
Flag ObjName1 ObjName2 Ang Ang2 Pt1 Pt2 Pt3 Pt4
princ
\n
convert two dimensions to total Dimension on the same position"
princ
\n
setq
*error*
myerror
SD1028
setq
LegLen
7.0
setq
Flag
nil
get_layer
ltype
color
RegistryRead_1001
setvar
"Clayer"
Lay1
setvar
"Cecolor"
Col1
setvar
"Celtype"
LT1
while
Flag
nil
setq
ObjName1
car
entsel
\n
Select 1st Dimension :"
if
and
ObjName1
cdr
assoc
0
setq
Data1
entget
ObjName1
"DIMENSION"
setq
Flag T
redraw
ObjName1
3
setq
theStyle
SD3511
3
ObjName1
setq
Flag
nil
while
Flag
nil
setq
ObjName2
car
entsel
\n
Select 2nd Dimension :"
if
and
ObjName2
cdr
assoc
0
setq
Data2
entget
ObjName2
"DIMENSION"
or
equal
abs
cdr
assoc
50
Data1
cdr
assoc
50
Data2
0.0
0.0001
equal
abs
cdr
assoc
50
Data1
cdr
assoc
50
Data2
pi
0.0001
setq
Flag T
princ
\n
two dimensions should have same angle"
redraw
ObjName1
4
setq
PList
list
cdr
assoc
13
Data1
cdr
assoc
14
Data1
cdr
assoc
13
Data2
cdr
assoc
14
Data2
setq
PList2
list
cdr
assoc
10
Data1
cdr
assoc
10
Data2
if
distance
cdr
assoc
14
Data1
cdr
assoc
10
Data1
0
setq
Ang
angle
cdr
assoc
14
Data1
cdr
assoc
10
Data1
setq
Ang
angle
cdr
assoc
13
Data1
cdr
assoc
14
Data1
0.5
pi
setq
Ang2
Ang
0.5
pi
;?C[
setq
ItsLayer
cdr
assoc
8
Data1
setq
PList_n
mapcar
lambda
x
SD1862 x Ang2
PList
setq
PList2_n
mapcar
lambda
x
SD1862 x Ang2
PList2
setq
PList_n_x
mapcar
car
PList_n
setq
PList2_n_y
mapcar
cadr
PList2_n
setq
Position1
vl-position
apply
min
PList_n_x
PList_n_x
setq
Position2
vl-position
apply
max
PList_n_x
PList_n_x
setq
Position3
vl-position
apply
max
PList2_n_y
PList2_n_y
setq
Pt1
nth
Position1 PList
; (checkcircle Pt1 1.0 "A21")
setq
Pt2
nth
Position2 PList
; (checkcircle Pt2 1.0 "A31")
setq
Pt3
nth
Position3 PList2
; (checkcircle Pt3 1.0 "A51")
; (setq Pt4 (polar Pt3 Ang (* LegLen Scale)))
; (checkcircle Pt4 1.0 "A21")
setq
Pt1
trans
Pt1
0
1
Pt2
trans
Pt2
0
1
Pt3
trans
Pt3
0
1
; Pt4 (trans Pt4 0 1)
setq
UAng
angle
0
0
getvar
"UCSXDIR"
setq
Ang2
Ang2 UAng
command
"._dimstyle"
"RE"
theStyle
command
"dimrotated"
180
Ang2 pi
Pt1 Pt2 Pt3
command
"change"
entlast
"P"
"LA"
ItsLayer
entdel
ObjName1
entdel
ObjName2
SD2056
setq
*error*
nil
princ
defun
RegistryRead_1001
setq
Path1001
"HKEY_CURRENT_USER
Software
SpeedDraftLT
SD_1001"
if
vl
registry
read
Path1001
"LegLen"
progn
set_tile
"LegLen"
vl
registry
read
Path1001
"LegLen"
setq
LegLen
atof
vl
registry
read
Path1001
"LegLen"
setq
LegLen
7.0
if
and
vl
registry
read
Path1001
"Lay1"
member
vl
registry
read
Path1001
"Lay1"
Laylist1
progn
set_tile
"Lay1"
itoa
vl-position
vl
registry
read
Path1001
"Lay1"
Laylist1
setq
Lay1
vl
registry
read
Path1001
"Lay1"
progn
setq
Lay1
getvar
"Clayer"
set_tile
"Lay1"
itoa
vl-position
Lay1 Laylist1
if
and
vl
registry
read
Path1001
"LT1"
member
vl
registry
read
Path1001
"LT1"
Laylist3
progn
set_tile
"LT1"
itoa
vl-position
vl
registry
read
Path1001
"LT1"
Laylist3
setq
LT1
vl
registry
read
Path1001
"LT1"
progn
setq
LT1
"ByLayer"
set_tile
"LT1"
"0"
if
and
vl
registry
read
Path1001
"Col1"
member
vl
registry
read
Path1001
"Col1"
Laylist2
progn
set_tile
"Col1"
itoa
vl-position
vl
registry
read
Path1001
"Col1"
Laylist2
setq
Col1
vl
registry
read
Path1001
"Col1"
progn
setq
Col1
"ByLayer"
set_tile
"Col1"
"0"
defun
SD1028
setq
OldCmdEcho
getvar
"CMDECHO"
setvar
"CMDECHO"
0
command
"undo"
"be"
setq
OldOsmode
getvar
"OSMODE"
setq
OldLayer
getvar
"CLAYER"
setq
OldLType
getvar
"CeLType"
setq
OldCeLWeight
getvar
"CeLWeight"
setq
OldColor
getvar
"CeColor"
setq
OldOrtho
getvar
"ORTHOMODE"
setq
OldDStyle
getvar
"DIMSTYLE"
setq
OldExpert
getvar
"Expert"
setvar
"EXPERT"
0
setq
Path_Lang
"HKEY_CURRENT_USER
Software
SpeedDraftLT"
; (if (vl-registry-read Path_Lang "SD_Language" )
; (setq SD:Lang (vl-registry-read Path_Lang "SD_Language" ))
; (progn (setq SD:Lang "J")
; (vl-registry-write Path_Lang "SD_Language" "J")
princ
defun
SD2056
setvar
"OSMODE"
OldOsmode
command
"undo"
"end"
setvar
"CLAYER"
OldLayer
setvar
"CeLType"
OldLType
setvar
"CeLWeight"
OldCeLWeight
setvar
"CeColor"
OldColor
setvar
"ORTHOMODE"
OldOrtho
setvar
"Expert"
OldExpert
if
and
getvar
"DIMSTYLE"
OldDStyle
tblsearch
"DIMSTYLE"
OldDStyle
command
"-dimstyle"
"Restore"
OldDStyle
princ
\n
(C)OffshoreCad&Management"
setvar
"CMDECHO"
OldCmdEcho
princ
defun
get_layer
ltype
color
setq
Lay
tblnext
"LAYER"
T
LT
tblnext
"LTYPE"
T
Laylist1
list
Laylist2
list
"ByLayer"
"Red"
"Yellow"
"Green"
"Cyan"
"Blue"
"Magenta"
"B/W"
Laylist3
list
"ByLayer"
While
Lay
setq
lay1
list
cdr
assoc
2
Lay
lay2
cdr
assoc
62
Lay
lay3
list
cdr
assoc
6
Lay
Laylist1
append
Laylist1 lay1
Laylist3
append
Laylist3 lay3
Lay
tblnext
"LAYER"
if
lay2
7
setq
lay2
list
itoa
lay2
Laylist2
append
Laylist2 lay2
While
LT
setq
lay3
list
cdr
assoc
2
LT
Laylist3
append
Laylist3 lay3
LT
tblnext
"LTYPE"
setq
Laylist1
RemoveOverlap Laylist1
Laylist2
RemoveOverlap Laylist2
Laylist3
RemoveOverlap Laylist3
defun
RemoveOverlap
List2
List1
while
List2
setq
List1
append
List1
list
car
List2
setq
List2
vl-remove
car
List2
List2
List1
;;;---------Rotate----------------------------
defun
SD8446
PointA PointB Ang
XA YA XB YB PointC
setq
XA2
car
PointA
car
PointB
YA2
cadr
PointA
cadr
PointB
setq
PointC
list
XA2
cos
Ang
YA2
sin
Ang
XA2
sin
Ang
YA2
cos
Ang
setq
PointC
mapcar
PointC PointB
PointC
defun
SD1862
OldPt Ang
NewCs
setq
NewCs
SD8446 '
1
0
0
0
Ang
setq
NewPt
trans
OldPt
0
NewCs
setq
NewPt
list
nth
2
NewPt
nth
0
NewPt
NewPt
defun
SD3511
g e
cond
type
e
'ename
cdr
assoc
g
entget
e
type
e
list
cdr
assoc
g e
defun
myerror
msg
setq
*error*
nil
SD2056
princ
\n
Error in SpeedDraftLT"
princ
princ
\n
Command Name: JDIMS"
princ
Logged
DEVITG
Bull Frog
Re: help with join dimension lisp
Reply #1 on:
August 08, 2020, 04:34:15 PM »
For better understanding, and to get further help, please upload such sample.dwg
Logged
Location @ Crdoba Argentina Using ACAD 2019 at Window 10
PM
Guest
Reply #2 on:
August 08, 2020, 04:39:22 PM »
here is a dwg of my te4mplate settings
Logged
PM
Guest
Reply #3 on:
August 09, 2020, 03:41:49 AM »
any ideas?
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
