Trying to get filename to use but there is error
HasanCAD:
I am trying to use file name as a prefix but when press enter result is not the filename
--- Code - Auto/Visual Lisp: ---(setq filepath (getvar "dwgname"))(setq filename (VL-FILENAME-BASE filepath)) (setq fileprefix (cond ((getstring (strcat "\nEnter filename prefix: < " (setq fileprefix (cond (fileprefix) (filename) ) ) " >?: " ) ) ) (fileprefix) ))
The result is
--- Quote ---""
--- End quote ---
Keith™:
Check DWGTITLED
If it is 0 no path is included in DWGNAME
Dlanor:
Your condition (cond) is incorrect
Perhaps
--- Code - Auto/Visual Lisp: --- (setq filepath (getvar "dwgname")) (setq filename (VL-FILENAME-BASE filepath)) (setq fileprefix (cond ( (getstring (strcat "\nEnter filename prefix: < " (setq fileprefix (if (not fileprefix) filename)) " >?: "))) (t fileprefix) ) )
HasanCAD:
Thanks Keith
Thanks Dlaner but gives the same result
In command line shows the filename but when click Enter gives this
--- Code: ---"222-Layout2.dwg"
"222-Layout2"
--- End code ---
Dlanor:
What are you expecting to get?
Navigation
[0] Message Index
[#] Next page
Go to full version
