Author Topic: Re size Xlist Dialog Box  (Read 1792 times)
PHX cadie
« on: August 06, 2020, 11:24:49 AM »
We have a client with unusually long file names, so when I do a xl the only thing legible is the xref name, the layer name is cut off
I'm sure others have had this prob, but I didn't see any search results with this issue
If there is not an existing answer, pls don't go to any trouble, I've been doing a ncopy then finding layer   :uglystupid2:
- vanilla 2016, C3D 2017/18 -
Hope everyone is doing well, Mark stay safe, last I knew ur in the hurricane state. Thxs
Acad 2013 and XM
Crank
Re: Re size Xlist Dialog Box
« Reply #1 on: August 06, 2020, 12:51:19 PM »
There is also the -XLIST command so the result will placed on the command line.
XLISP is just a lisp from the EXPRESS TOOLS, so you can edit it so XLIST does the same as -XLIST :
(defun c:xlist ( / kUseDialog )
  (setq kUseDialog nil)
  (xlist kUseDialog)
Another option is to edit the width in the dialog file ( xlist.dcl )
PHX cadie
« Reply #2 on: August 06, 2020, 02:33:21 PM »
thank you Sir :)
Acad 2013 and XM
« Reply #3 on: August 06, 2020, 02:44:28 PM »
Here is an old one I wrote when I didn't like what 'xlist' returned.  I still use it.
http://www.theswamp.org/index.php?topic=18121.0
