Author Topic: Isocircles  (Read 1584 times)
notredave
Isocircles
« on: August 05, 2020, 10:52:53 AM »
Good morning,
I am having a time trying to get an ellipse-->isocircle in isodraft to give me the correct diameter when I do a distance between quadrants. For example, if I draw an isocircle with a diameter of 1" and dimension it, it gives 1.2247" across quadrants. Is there a way to draw an isocircle with diameter inputted to output correct diameter when dimensioning it?
Thank you,
Dave
Crank
Re: Isocircles
« Reply #1 on: August 05, 2020, 03:35:39 PM »
It's just math (in radians)
If you draw a circle with radius=1 and add some lines and angles, we get:
(setq Rmin (cos (* pi .25)))
(setq Rmax (* Rmin (sqrt 3.)))
So:
(setq Rmin (* 0.5 (sqrt 2.)))
(setq Rmax (* 0.5 (sqrt 6.)))
