CAD Forums > CAD General
Isocircles
(1/1)
notredave:
Good morning,
I am having a time trying to get an ellipse-->isocircle in isodraft to give me the correct diameter when I do a distance between quadrants. For example, if I draw an isocircle with a diameter of 1" and dimension it, it gives 1.2247" across quadrants. Is there a way to draw an isocircle with diameter inputted to output correct diameter when dimensioning it?
Thank you,
Dave
Crank:
It's just math (in radians)
If you draw a circle with radius=1 and add some lines and angles, we get:
--- Code: ---(setq Rmin (cos (* pi .25)))
(setq Rmax (* Rmin (sqrt 3.)))
--- End code ---
So:
--- Code: ---(setq Rmin (* 0.5 (sqrt 2.)))
(setq Rmax (* 0.5 (sqrt 6.)))
--- End code ---
Navigation
[0] Message Index
Go to full version
