[CommandMethod("BRKPL")]
public void BreakLineOrPolyline()
var doc = Acad.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
var entityOptions
= new PromptEntityOptions
("\nSelect line or polyline: "); entityOptions.SetRejectMessage("Selected object is neither a line nor a polyline.");
entityOptions
.AddAllowedClass(typeof(Polyline
true); entityOptions
.AddAllowedClass(typeof(Line
true); var entityResult = ed.GetEntity(entityOptions);
if (entityResult.Status != PromptStatus.OK)
return;
Point3d pt1, pt2;
var ucs = ed.CurrentUserCoordinateSystem;
var pointOptions
= new PromptPointOptions
("\nSpecify second point or [First point]: ",
"First"); var pointResult = ed.GetPoint(pointOptions);
if (pointResult.Status == PromptStatus.Keyword)
pointOptions.Message = "\nSpecify first point: ";
pointOptions.Keywords.Clear();
if (pointResult.Status != PromptStatus.OK)
return;
pt1 = pointResult.Value.TransformBy(ucs);
pointOptions.Message = "\nSpecify second point: ";
return;
pt2 = pointResult.Value.TransformBy(ucs);
else if (pointResult.Status == PromptStatus.OK)
pt1 = entityResult.PickedPoint.TransformBy(ucs);
else return;
using (var tr = db.TransactionManager.StartTransaction())
var curve = (Curve)tr.GetObject(entityResult.ObjectId, OpenMode.ForWrite);
double param1 = curve.GetParameterAtPoint(curve.GetClosestPointTo(pt1, false));
double param2 = curve.GetParameterAtPoint(curve.GetClosestPointTo(pt2, false));
var parameters
= new DoubleCollection
(new[] { param1, param2
} .Distinct()
.OrderBy(x => x)
.ToArray());
var curves = curve.GetSplitCurves(parameters);
var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
switch (curves.Count)
case 3:
curSpace.AppendEntity((Entity)curves[0]);
tr.AddNewlyCreatedDBObject(curves[0], true);
curSpace.AppendEntity((Entity)curves[2]);
tr.AddNewlyCreatedDBObject(curves[2], true);
curves[1].Dispose();
curve.Erase();
break;
case 2:
curSpace.AppendEntity((Entity)curves[1]);
tr.AddNewlyCreatedDBObject(curves[1], true);
curve.Erase();
break;
default:
break;
tr.Commit();
