Author Topic: Disappearing Profiles  (Read 4595 times)
Dave M
« on: July 22, 2020, 11:19:47 AM »
I have created some profiles that are projected onto another alignment, and they display as expected.  I made data shortcuts for them, and displayed them in another dwg.  Everything is fine until I close and reopen the dwg.  When I reopen the file they are not displayed.  The toolspace lists them, but no display.  Even if I delete the shortcutted versions and redisplay them, they will be gone the next time I open the file.
Anyone else experience this?  I don't what to do short of exploding the shortcutted versions after displaying them
Thanks,
Dave
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
PHX cadie
Re: Disappearing Profiles
« Reply #1 on: August 06, 2020, 11:42:49 AM »
I recently had a project with every problem imaginable....
1. a shortcut EG surface not displaying. Just out the blue we tried View tab>View pulldown > Level of Detail, (turn off) do it again (turn on) and a regenall (?) displayed my surface
Hopefully it works + not too late
Acad 2013 and XM
Dave M
« Reply #2 on: August 07, 2020, 11:23:06 AM »
Thanks for the tip, I will give it a try!
