Searching for free block viewer like this
HasanCAD:
Is there a free block viewer like this to use in inserting blocks?
tombu:
Appears to be an Image Tile Menu. You have to build it. No lisp needed. In the CUI under Legacy → Image Tile Menu are 3 you can check out that you've already used.
About Customizing Image Tile Menus https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-LT/files/GUID-2E5F1395-B882-47B8-91F4-F58775BDE0FB-htm.html
Create Image Tile Menus (Concept) https://documentation.help/AutoCAD-ACG/WS73099cc142f4875513fb5cd10c4aa30d6b-7be5.htm
Lee Mac:
You could build something using this:
https://www.theswamp.org/index.php?topic=42413.0
BIGAL:
Its a simple process of making slides and a MNU using notepad etc. You can make from scratch not using the CUI. Nice thing is it does multi page automatically if more than 1 screen full.
Other alternatives is custom dcl again with images. I have 2x2 3x2 4x4 etc.
HasanCAD:
Thanks tombu
Thanks LEE
Thanks BIGAL, Is there an example to use as a start and follow?
Navigation
[0] Message Index
[#] Next page
Go to full version
