Author Topic: How to assign a variable name inside autocad to 'coded variable'  (Read 1315 times)
badjo_5
  • Mosquito
I don't even know how to ask a question, so this is the explanation of what i want to achieve. I try to do something like Civil: when I create a point group (or topology, or surface, or....) I name that point group, and then within the document I can use the name of the point group (or ...), not the name of some variable that is given inside the application. Then I call my Command with that created name as an input parameter.
Or a simpler example: a list of all created topologies in the drawing.
This should probably be some kind of collection or dictionary maybe.
huiz
  • Certified Prof C3D
Re: How to assign a variable name inside autocad to 'coded variable'
« Reply #1 on: July 03, 2020, 01:59:28 AM »
You mean like the GROUP command?
badjo_5
  • Mosquito
« Reply #2 on: July 03, 2020, 01:02:13 PM »
Picture.
I am using NTS for creating small topolgyes and stuff..
