Author Topic: list property added to AECC-COGO_POINT  (Read 3439 times)
FELIX
« on: June 26, 2020, 10:00:17 PM »
How to list the values of a property added to the AECC-COGO_POINT?
OK.
Dilan
Re: list property added to AECC-COGO_POINT
« Reply #1 on: June 27, 2020, 04:53:46 PM »
Hi, maybe like this:
(defun cogo_list_Collect ( ss / i l o ss )
(repeat (setq i (sslength ss))
            (setq i (1- i)
                  o (vlax-ename->vla-object (ssname ss i))
                  l (cons (mapcar '(lambda ( p ) (vlax-get o p)) '(easting northing elevation)) l)
     l
Example:
(cogo_list_Collect (ssget '((0 . "AECC_COGO_POINT"))))
FELIX
« Reply #2 on: June 27, 2020, 06:25:41 PM »
Dilan, these are not properties (easting northing elevation). These are the ones that have been added (Sigma E, Sigma N, Sigma Z), see the attached drawing.
OK.
Dilan
« Reply #3 on: June 27, 2020, 10:55:53 PM »
I have no such properties in civil
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: June 28, 2020, 12:28:13 AM »
You will need to change your CIV3D style to display sigmas, or do you want to get the aecc point details for some thing else.
There are various ways but bottom line is get properties of a Aecc point the issue is the sigmas may be in a separate area but linked via pt number. Need sample dwg.
wizman
« Reply #5 on: June 28, 2020, 01:26:03 AM »
Export Points > Create a point file format of using user defined properties. e.g. PEDSeSnSz
FELIX
« Reply #6 on: June 28, 2020, 10:28:28 AM »
see the DWG file I attached.
OK.
FELIX
« Reply #7 on: June 28, 2020, 10:37:52 AM »
It already contains a point with the style added by SIGMAS.
The function "(vlax-dump-object (vlax-ename-> vla-object ENTTS) T)" does not list SIGMAS as a property in Civil 3D but the AutoCAD command "LIST" does.
What I need is a LISP that reads these values. In this case of the drawing I have attached are 3 SIGMAs
SIGMAS are just a small test. Various other information will be added to the point in Civel 3D.
OK.
FELIX
« Reply #8 on: June 28, 2020, 10:40:48 AM »
OK.
wizman
« Reply #9 on: June 28, 2020, 02:34:39 PM »
Set the point group classification to Sigmas or All.  In your dwg, it is set to none.
Then to read the UDP's:
  1. (setq wiz (vlax-ename->vla-object (car (entsel "\nPick a point: "))))
  2. (foreach x '("Sigma E" "Sigma N" "Sigma Z")
  3. (princ (strcat "\n"(vlax-invoke wiz 'GetUserDefinedPropertyValue x))))
EDIT (John): Added code tags.
« Last Edit: June 28, 2020, 03:15:06 PM by John Kaul (Se7en) »
FELIX
« Reply #10 on: June 28, 2020, 05:49:17 PM »
PERFECT, EXCELLENT, THANK YOU.
OK.
wizman
« Reply #11 on: June 29, 2020, 12:16:12 AM »
glad to help, cheers.
