Author Topic: 3D portal - search by drawing or sketch  (Read 6438 times)
Dape
  • Mosquito
« on: June 24, 2020, 05:32:38 AM »
Hi all,
I am new here, so I was wondering is there any 3D portal where you can search for the needed part or model by drawing or sketch?
Or where it can give you many similar models based on that basic sketch?
The only one I have found it this one here 3DfindIT.com
https://www.3dfindit.com/?lang=en_US
Any other portals with the same options maybe?
Thank you in advance!
 :smitten:
DeeGeeCees_V.2.0
Re: 3D portal - search by drawing or sketch
« Reply #1 on: June 24, 2020, 11:57:21 AM »
I use these websites to find premade 3D things:
https://3dwarehouse.sketchup.com
https://grabcad.com/library
Lonnie
« Reply #2 on: June 24, 2020, 04:42:01 PM »
I use half a dozen. To name a few bimobject Revitcity onshape and thingiverse. Depends on what I am doing and what format I need. Between one program or another I typically can get what's needed into the format I need pretty quick.
The one you posted will go on my list of places to look. Thank You.
Dape
  • Mosquito
« Reply #3 on: June 25, 2020, 02:50:43 AM »
Thank you both for you quick response, I appreciate it. I am familiar with most of the 3D portals, but sometimes I look for something and the easiest way is just to draw it, sketch it and then look for the similar parts/models. Sometimes I need functionality, too. This is why I was wondering is there any other 3D search engine based on that. The only one I have found is that one I mentioned in my post - 3DfindIT.com
Once again, thank you for your help!
