Author Topic: get coordinates of a polar parameter grip of a dynamic block  (Read 1093 times)
Red Nova
I am trying to get the XY coordinate of a grip that belongs to a Polar Parameter of a dynamic block.
I know how to get values of properties of the block including dynamic properties.
I tried to solve this by getting Polar Distance, Polar Angle, Rotation, Flip and Mirror values and apply some math.
However, this does not work. The tricky part is that with a Polar Parameter after the user has interacted with flip and polar grips a few times, 2 blocks now can have same values of dynamic properties (and regular properties) and still the position on the plan will different.
See attached example, blocks 1 and 2 have same properties.
Is it possible to get the XY coordinate of the Polar Parameter for any case?
Thank you
