Author Topic: Import kmz with placemark labels  (Read 3957 times)
dubb
« on: June 11, 2020, 04:04:28 PM »
When using mapimport on map3d. I don't see any option to label the imported points. Am I missing a step?
Rod
Re: Import kmz with placemark labels
« Reply #1 on: June 14, 2020, 06:14:20 PM »
You can either
Import the data and attach object data to the point and then use mapannotation to create labels
OR
Create a block with an attribute or attributes that you want to use as labels they must have the same attribute tag as the input layer name, then use the points dropdown on the right to select the block name.
Upload the kmz if you need more help.
Cheers, Rod.
« Last Edit: June 14, 2020, 11:20:24 PM by Rod »
"All models are wrong, some models are useful" - George Box
