Author Topic: Transient graphics not showing Text  (Read 2839 times)
ROYNIJKAMP
  • Mosquito
« on: June 11, 2020, 07:25:19 AM »
I am displaying a temporary line between 2 picked polylines.
The line is showing as expected execept for the Text object.
I have tried to add a Text to the Transient Graphics, but is it not showing.
Why is the Text not showing, is it not possible to show the text on the Fly?
Below the code i use.
Code - vb.net: [Select]
  1. Public Class clsMarkerLine
  2.     Private Shared plStart As Polyline
  3.     Private Shared plEind As Polyline
  4.
  5.     Private Shared m_markers As DBObjectCollection = New DBObjectCollection()
  6.     Private Shared collectints As IntegerCollection = New IntegerCollection()
  7.
  8.     Public Shared Sub StartMarker(ByVal polyStart As Polyline, ByVal polyEind As Polyline)
  9.         Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
  10.         AddHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
  11.         plStart = polyStart
  12.         plEind = polyEind
  13.     End Sub
  14.
  15.     Public Shared Sub StopMarker()
  16.         Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
  17.         ed.TurnForcedPickOn()
  18.         RemoveHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor)
  19.         ClearMarkers()
  20.     End Sub
  21.
  22.     Private Shared Sub ed_PointMonitor(ByVal sender As Object, ByVal e As PointMonitorEventArgs)
  23.         showLine(e.Context.RawPoint)
  24.     End Sub
  25.
  26.     Private Shared Sub showLine(ByVal pt As Point3d)
  27.         ClearMarkers()
  28.         'marker line
  29.         Dim myLine As Line = dynLine(pt)
  30.         m_markers.Add(myLine)
  31.         aGi.TransientManager.CurrentTransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints)
  32.                 'marker text
  33.         Dim myText As DBText = dynLineLengthText(pt, myLine)
  34.         m_markers.Add(myText)
  35.         aGi.TransientManager.CurrentTransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints)
  36.
  37.     End Sub
  38.
  39.     Public Shared Function dynLine(pt As Point3d, Optional sLayer As String = "0") As Line
  40.         Dim myLine As Line = New Line()
  41.         myLine.StartPoint = pt
  42.         myLine.EndPoint = plStart.GetClosestPointTo(pt, True)
  43.         Dim pts As New Point3dCollection()
  44.         myLine.IntersectWith(plEind, Intersect.ExtendThis, pts, New IntPtr(0), New IntPtr(0))
  45.         If pts.Count > 0 Then
  46.             myLine.StartPoint = pts(0)
  47.         End If
  48.         myLine.Layer = sLayer
  49.         myLine.ColorIndex = 10
  50.         dynLine = myLine
  51.     End Function
  52.
  53.
  54.
  55.     Public Shared Function dynLineLengthText(pt As Point3d, ln As Line, Optional sLayer As String = "0") As DBText
  56.         Dim acText As DBText = New DBText()
  57.         Dim dStart As Double = (ln.StartPoint.X + ln.EndPoint.X) / 2
  58.         Dim dEind As Double = (ln.StartPoint.Y + ln.EndPoint.Y) / 2
  59.         Dim ptCenter As Point3d = New Point3d(dStart, dEind, 0)
  60.         Dim CustomLineParmameters As CustomLineParam = getCustomLineParam(ln, ptCenter, True, False, 0.0, 0.5)
  61.         Dim newAngle As Double = CustomLineParmameters.Angle
  62.
  63.         acText.Rotation = newAngle * Math.PI / 180
  64.         acText.TextString = Math.Round(CustomLineParmameters.LineLength, 2).ToString & " m"
  65.         acText.Position = CustomLineParmameters.Point
  66.         acText.Layer = sLayer
  67.         acText.ColorIndex = 10
  68.         dynLineLengthText = acText
  69.     End Function
  70. End Class
n.yuan
Re: Transient graphics not showing Text
« Reply #1 on: June 11, 2020, 12:12:06 PM »
  2.
  3.     ...
  4.     Private Shared collectints As IntegerCollection = New IntegerCollection()
  5.
  6.    ...
  7.
  8.     Private Shared Sub showLine(ByVal pt As Point3d)
  9.         ClearMarkers()
  10.         'marker line
  11.         Dim myLine As Line = dynLine(pt)
  12.         m_markers.Add(myLine)
  13.         aGi.TransientManager.CurrentTransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints)
  14.                 'marker text
  15.         Dim myText As DBText = dynLineLengthText(pt, myLine)
  16.         m_markers.Add(myText)
  17.         aGi.TransientManager.CurrentTransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints)
  18.
  19.     End Sub
  20.
  21.     ...
  22.
  23. End Class
I think the issue lies in the argument of IntegerCollection passed into AddTransient() method: you need to pass a new/empty IntegerCollection, not one shared by multiple calls, like:
TransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection())
TransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection())
huiz
  • Certified Prof C3D
« Reply #2 on: June 11, 2020, 01:24:54 PM »
I am not sure if it is impossible but I had only success with shx fonts, not with ttf fonts.
« Reply #3 on: June 11, 2020, 01:29:04 PM »
I have always used the single IntergerCollection for any number of objects to be displayed, Norman.
If the text style used is a TrueType font, trying changing to one that uses an SHX font. I seem to recall having issues with TT fonts in TransientGraphics. huiz beat me to this.
n.yuan
« Reply #4 on: June 11, 2020, 06:09:39 PM »
Good to know, Jeff. Thanks.
ROYNIJKAMP
  • Mosquito
« Reply #5 on: June 15, 2020, 05:07:53 AM »
Thanks for the quick responses.
At the moment i have tried 2 options with SHX text with no luck at all.
What i tried so far:
option 1
  • manual created a text style with SHX font
  • set new created style as default/current
  • Create a DBText object with just a TextString and a Position and add it to the Transientmanager
option 2
  • create a shx textstyle by code
  • set textstyle as default/current
  • Create a DBText object with just a TextStyle objectid, TextString and a Position and add it to the Transientmanager
Is so difficult to show the Text object or am i missing something?
« Reply #6 on: June 15, 2020, 06:23:10 PM »
You aren't setting the DBText to use a TextStyle. Also, if the Style doesn't have a defined height, you need to also set that. Here I'm tracking along a street alignment and added the word Test to the cursor location.
This is the code to show the graphics:
Code - C#: [Select]
  1.         private void showLine_and_X(Point3d curPt, Point3d pt3, double scale)
  2.         {
  3.             ClearMarkers();
  4.             Line line1 = new Line(curPt, pt3);
  5.             Line line2 = new Line(Utility.PolarPoint(pt3, line1.Angle + (Math.PI * 0.25), 0.15 * scale), Utility.PolarPoint(pt3, line1.Angle + (Math.PI * 1.25), 0.15 * scale));
  6.             Line line3 = new Line();
  7.             line3.StartPoint = line2.StartPoint;
  8.             line3.EndPoint = line2.EndPoint;
  9.             line3.TransformBy(Matrix3d.Rotation(Math.PI * 0.5, Vector3d.ZAxis, pt3));
  10.             line1.ColorIndex = 1;
  11.             line2.ColorIndex = 3;
  12.             line3.ColorIndex = 3;
  13.             var txt = new DBText();
  14.             txt.TextString = "Test";
  15.             txt.Position = curPt;
  16.             txt.TextStyleId = styleid; //this is saved as a global variable in the command code
  17.             txt.Height = 4.0;
  18.             aGi.TransientManager.CurrentTransientManager.AddTransient(line1, aGi.TransientDrawingMode.DirectShortTerm, 128, intColl);
  19.             aGi.TransientManager.CurrentTransientManager.AddTransient(line2, aGi.TransientDrawingMode.DirectShortTerm, 128, intColl);
  20.             aGi.TransientManager.CurrentTransientManager.AddTransient(line3, aGi.TransientDrawingMode.DirectShortTerm, 128, intColl);
  21.             aGi.TransientManager.CurrentTransientManager.AddTransient(txt, aGi.TransientDrawingMode.DirectShortTerm, 128, intColl);
  22.
  23.             m_mrkers.Add(line1);
  24.             m_mrkers.Add(line2);
  25.             m_mrkers.Add(line3);
  26.             m_mrkers.Add(txt);
  27.         }
  28.
« Last Edit: June 15, 2020, 07:15:09 PM by Jeff_M »
ROYNIJKAMP
  • Mosquito
« Reply #7 on: July 02, 2020, 06:16:00 AM »
Thanks Jeff for pointing me in the right direction.
The problem was not defining a height in my style and not when creating the text.
After setting the height my Text is shown.
I'm feeling stuppid to overlook this. :uglystupid2:
CADbloke
  • Crash Test Dummy
« Reply #8 on: July 03, 2020, 07:02:16 PM »
.SetDatabaseDefaults() can avoid some of these kinds of hassles. Not all, just some.
