Author Topic: how select polyline and get current coordinates  (Read 737 times)
franciscocsilva
  • Mosquito
« on: June 08, 2020, 07:35:36 AM »
hello
who can help me?
I need select a polyline and read startpint ans end point in a current coordinate system.
I have this:
Dim id1 As ObjectId = SelectSpecificObjectType(vbLf & "Select polyline: ", GetType(Polyline))
        If id1.IsNull Then
            Return
        End If
Private Shared Function SelectSpecificObjectType(ByVal prompt As String, ByVal objectClass As System.Type) As ObjectId
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Using tr As Transaction = ed.Document.Database.TransactionManager.StartTransaction()
            While True
                Dim res As PromptEntityResult = ed.GetEntity(prompt)
                If res.Status <> PromptStatus.OK Then
                    Return ObjectId.Null
                End If
                Dim ob As DBObject = tr.GetObject(res.ObjectId, OpenMode.ForRead)
                If objectClass.IsAssignableFrom(ob.[GetType]()) Then
                    Return res.ObjectId
                End If
                ed.WriteMessage(vbLf & "Invalid selection, {0} entity expected", RXClass.GetClass(objectClass).DxfName)
            End While
        End Using
Dim lineA As Polyline = CType(acTrans.GetObject(id2, OpenMode.ForRead), Polyline)
 IntersectionPointA = lineIntersectors(AuxMuroA.StartPoint, AuxMuroA.EndPoint, lineA.StartPoint, lineA.EndPoint)
i need a current user coordinates system for lineA.
thank you
n.yuan
Re: how select polyline and get current coordinates
« Reply #1 on: June 09, 2020, 10:44:17 AM »
Entity's coordinates in database are always World. If you need the coordinate in current UCS, simply transform the coordinate point with Editor.CurrentUserSystemCoordinate:, something like:
var ed=Application.DocumentManager.MdiDocument.Editor;
var startPt=LineA.StartPoint.TransformBy(ed.CurrentUserCoorinateSystem);
var endPt=LineA.EndPoint.TransformBy(ed.CurrentUserCoorinateSystem);
Similarly, if you picked point in current UCS that is different from World, before you use the point to do calculation with entity, you would translate the picked point into World coordinate system by transforming it with Editor.CurrentUserCooordinateSystem.Inverse().
franciscocsilva
  • Mosquito
« Reply #2 on: July 20, 2020, 07:19:14 AM »
Thank you very much
emrahctrk
  • Mosquito
« Reply #3 on: October 15, 2020, 08:08:15 AM »
do you have C# codes for this solution?
Atook
