Author Topic: Split big list...  (Read 6219 times)
ribarm
  • Marko Ribar, architect
Split big list...
« on: May 27, 2020, 07:27:24 AM »
Hi...
Here is the task (small challenge) :
You have big list with elements that are not unique - so there may be repetitions...
The goal : You need to split big list into 2 or more smaller lists, but without using iteration and recursion - in the fastest way possible...
If you have some suggestion, please step in...
Cheers...
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
Re: Split big list...
« Reply #1 on: May 27, 2020, 07:57:12 AM »
Post a sample list (short) and results...
ribarm
« Reply #2 on: May 27, 2020, 08:06:06 AM »
Don't have any particular - can be any but with repeating elements...
For me it's good solution if you could split it at half or approximately at position (nth (fix (/ (length lst) 2.0)) lst)...
M.R. on Youtube
« Reply #3 on: May 27, 2020, 08:23:22 AM »
I got the second half (if the list is short):
  1. ( (lambda ()
  2.     (setq a_lst '(0 1 2 3 4 5 6 7)
  3.           opperator "d"
  4.           num (length a_lst)
  5.           int 1
  6.           temp "c")
  7.     (while (<= int (/ num 2))
  8.            (setq temp (strcat temp opperator)
  9.                  int (+ int 1)))
  10.     (setq temp (strcat temp "r"))
  11.     (eval (list (read temp) (quote a_lst)))
  12.     )
  13.  )
Why are you splitting lists? When you have large, messy, lists operations on that list can take some time--especially if you are iterating that list several times trying to, unnecessarily "sort it alphabetical".
ribarm
« Reply #4 on: May 27, 2020, 08:27:48 AM »
You are iterating with (while) and plus you have a_lst unique elements - elements should repeat randomly...
M.R. on Youtube
« Reply #5 on: May 27, 2020, 08:33:08 AM »
My solution wasn't really practical. My question remains though; list operations can be unnecessary so wouldn't a different design approach be better in some cases?
Marc'Antonio Alessi
  • Marco
« Reply #6 on: May 27, 2020, 09:07:54 AM »
With long list maybe you can try my ALE_List_NthCdr "demential" solution:
(setq   aList '("01" "02" "03" "04" "05" "06" "07" "08" "09" "10" "11" "12" "13" "14" "15")) => ("01" "02" "03" "04" "05" "06" "07" "08" "09" "10" "11" "12" "13" "14" "15")
(setq   aLeng   (length aList)) => 15
(setq   aMLen  (fix (/ (length aList) 2.0))) => 7
(ALE_List_LastN   aMLen aList) => ("09" "10" "11" "12" "13" "14" "15")
(ALE_List_FirstN  (- aLeng aMLen) aList) => ("01" "02" "03" "04" "05" "06" "07" "08")
(length (setq aList (atoms-family 1))) => 4091
(progn (repeat 10 (setq aList (append aList aList))) (princ))
(setq   aLeng   (length aList)) => 4189184
(setq   aMLen  (fix (/ (length aList) 2.0))) => 2094592
(length (ALE_List_LastN   aMLen aList)) => 2094592
(length (ALE_List_FirstN  (- aLeng aMLen) aList)) => 2094592
(defun ALE_List_NthCdr (n l)
  (repeat (/       n              1000) (setq l (Cd1000r l)))
  (repeat (/ (setq n (rem n 1000)) 100) (setq l (Cd100r  l)))
  (repeat (/ (setq n (rem n  100))  10) (setq l (Cd10r   l)))
  (repeat (/ (setq n (rem n   10))   4) (setq l (cddddr  l)))
  (repeat (rem n 4)                     (setq l (cdr     l)))
  l
(defun ALE_List_LastN (n l)
  (ALE_List_NthCdr (- (length l) n) l)
(defun ALE_List_FirstN (n l)
  (reverse (ALE_List_NthCdr (- (length l) n) (reverse l)))
(defun Cd10r (l)
  (cddddr(cddddr(cddr l)))
(defun Cd100r (l)
  (cddddr(cddddr(cddddr(cddddr(cddddr(cddddr(cddddr
  (cddddr(cddddr(cddddr(cddddr l)))))))))))))))))))))))))
(defun Cd1000r (l)
  (cddddr(cddddr(cddddr(cddddr(cddddr l))))))))))))
ribarm
« Reply #7 on: May 27, 2020, 09:23:02 AM »
Thanks Marc' for you input... Actually my attempt is also iteration, similar to yours, but I suppose your is faster-better...
Here is my attempt :
(defun c:splitlsthalfs ( / memberpos lst pos len l1 l2 )
  (defun memberpos ( pos lst / k )
    (setq k -1)
    (while (< (setq k (1+ k)) pos)
      (setq lst (cdr lst))
    lst
  (setq lst '(1 2 3 2 1 2 3 2 1 4 5 6 5 4 6))
  (setq pos (fix (/ (setq len (length lst)) 2.0)))
  (setq l2 (memberpos pos lst))
  (setq l1 (if (= (rem len 2) 1) (reverse (cdr (memberpos pos (reverse lst)))) (reverse (memberpos pos (reverse lst)))))
  (princ "\n")
  (princ lst)
  (princ "\n")
  (princ (list l1 l2))
M.R. on Youtube
ribarm
« Reply #8 on: May 27, 2020, 09:49:31 AM »
I hope you don't mind - I steal your subs to make my own - here is where I'll use it :
  1. (defun car-sort ( l f / ALE_List_NthCdr ALE_List_LastN ALE_List_FirstN Cd10r Cd100r Cd1000r pos len l1 l2 al1 al2 a1 a2 )
  2.
  3.   (defun ALE_List_NthCdr (n l)
  4.     (repeat (/       n              1000) (setq l (Cd1000r l)))
  5.     (repeat (/ (setq n (rem n 1000)) 100) (setq l (Cd100r  l)))
  6.     (repeat (/ (setq n (rem n  100))  10) (setq l (Cd10r   l)))
  7.     (repeat (/ (setq n (rem n   10))   4) (setq l (cddddr  l)))
  8.     (repeat (rem n 4)                     (setq l (cdr     l)))
  9.     l
  10.   )
  11.   ;
  12.   (defun ALE_List_LastN (n l)
  13.     (ALE_List_NthCdr (- (length l) n) l)
  14.   )
  15.   (defun ALE_List_FirstN (n l)
  16.     (reverse (ALE_List_NthCdr (- (length l) n) (reverse l)))
  17.   )
  18.   ;
  19.   (defun Cd10r (l)
  20.     (cddddr(cddddr(cddr l)))
  21.   )
  22.   (defun Cd100r (l)
  23.     (cddddr(cddddr(cddddr(cddddr l)))))))))))))))))))))))))
  24.   )
  25.   (defun Cd1000r (l)
  26.     (cddddr(cddddr(cddddr(cddddr(cddddr l))))))))))))
  27.     )))))))))))))))))))))))))))))))))))))))))))))))))
  28.     )))))))))))))))))))))))))))))))))))))))))))))))))
  29.     )))))))))))))))))))))))))))))))))))))))))))))))))
  30.     )))))))))))))))))))))))))))))))))))))))))))))))))
  31.     ))))))))))))))))))))))))))))))))))))))))))
  32.   )
  33.
  34.   (setq pos (fix (/ (setq len (length l)) 2.0)))
  35.   (setq l1 (ALE_List_FirstN (- len pos) l))
  36.   (setq l2 (ALE_List_LastN pos l))
  37.
  38.   (cond
  39.     ( (and l1 l2)
  40.       (setq a1 (vl-some (function (lambda ( aa ) (setq al1 (cons aa al1)) (if (vl-every (function (lambda ( xx ) (apply f (list aa xx)))) (append (cdr al1) (setq l1 (cdr l1)))) aa))) l1))
  41.       (setq a2 (vl-some (function (lambda ( aa ) (setq al2 (cons aa al2)) (if (vl-every (function (lambda ( xx ) (apply f (list aa xx)))) (append (cdr al2) (setq l2 (cdr l2)))) aa))) l2))
  42.       (if (apply f (list a1 a2))
  43.         a1
  44.         a2
  45.       )
  46.     )
  47.     ( t
  48.       (car l)
  49.     )
  50.   )
  51. )
  52.
  53. ;;; (car-sort '(2 4 1 3 5 1) '<) => 1, (1 belongs to both l1 and l2) but generally it would be nil if single list processing, so better is '<= than '<
  54. ;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
  55.
For testing use something like :
(car-sort (atoms-family 1) '(lambda ( a b ) (<= (strlen a) (strlen b))))
Or opposite :
(car-sort (atoms-family 1) '(lambda ( a b ) (>= (strlen a) (strlen b))))
Compare speed with my previous version :
  1. (defun car-sort ( l f / removenth r k )
  2.
  3.   (defun removenth ( l n / k )
  4.     (setq k -1)
  5.     (vl-remove-if '(lambda ( x ) (= (setq k (1+ k)) n)) l)
  6.   )
  7.
  8.   (setq k -1)
  9.   (vl-some '(lambda ( a ) (setq k (1+ k)) (if (vl-every '(lambda ( x ) (apply f (list a x))) (removenth l k)) (setq r a))) l)
  10.   r
  11. )
  12.
  13. ;;; (car-sort '(2 4 1 3 5 1) '<) => nil
  14. ;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
  15.
It should be much faster-better then it was...
Thanks, M.R.
« Last Edit: May 27, 2020, 09:53:35 AM by ribarm »
M.R. on Youtube
Marc'Antonio Alessi
  • Marco
« Reply #9 on: May 27, 2020, 10:13:20 AM »
Your previous version with length 4.193.280
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 8 iteration(s):
    (ALE_LIST_FIRSTN AMLEN ALIST).....1281 / 3.15 <fastest>
    (MEMBERPOS AMLEN ALIST)...........4031 / 1 <slowest>
Elapsed milliseconds / relative speed for 32 iteration(s):
    (ALE_LIST_LASTN AMLEN ALIST)........1797 / 11.05 <fastest>
    (MEMBERPOSR AMLEN ALIST ALENG).....19859 / 1 <slowest>
ribarm
« Reply #10 on: May 27, 2020, 10:26:04 AM »
It is important to me that (car-sort) is now faster then it was before... This is especially important when you're dealing with routine that repeats inside loops only (car-sort), rather then (car (vl-sort))... In those cases there is no need to sort whole list over and over again and you need only first element of sorting... I believe that now my/your sub is closer to what's called built-in optimized autolisp function - and this one is new one - "congratualtions!!!"...
Can you improve it more?
Thanks for your help...
M.R. on Youtube
« Reply #11 on: May 27, 2020, 10:53:21 AM »
Unless I'm overlooking something about car-sort, why not just:
  1. (defun extremum ( cmp lst / rtn )
  2.    (setq rtn (car lst))
  3.    (foreach itm (cdr lst)
  4.        (if (apply cmp (list itm rtn)) (setq rtn itm))
  5.    )
  6.    rtn
  7. )
(Previously posted here.)
ribarm
« Reply #12 on: May 27, 2020, 10:58:25 AM »
There is still some issues with (car-sort)... Here is my testing function and results on my PC... (car (vl-sort)) should be the worst, but it proved the best... Something's weird going on...
  1. (defun c:test ( / car-sort-old car-sort-new l t0 t1 )
  2.
  3.   (defun car-sort-old ( l f / removenth r k )
  4.
  5.     (defun removenth ( l n / k )
  6.       (setq k -1)
  7.       (vl-remove-if '(lambda ( x ) (= (setq k (1+ k)) n)) l)
  8.     )
  9.
  10.     (setq k -1)
  11.     (vl-some '(lambda ( a ) (setq k (1+ k)) (if (vl-every '(lambda ( x ) (apply f (list a x))) (removenth l k)) (setq r a))) l)
  12.     r
  13.   )
  14.
  15.   ;;; (car-sort '(2 4 1 3 5 1) '<) => nil
  16.   ;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
  17.
  18.   (defun car-sort-new ( l f / ALE_List_NthCdr ALE_List_LastN ALE_List_FirstN Cd10r Cd100r Cd1000r pos len l1 l2 al1 al2 a1 a2 )
  19.
  20.     (defun ALE_List_NthCdr (n l)
  21.       (repeat (/       n              1000) (setq l (Cd1000r l)))
  22.       (repeat (/ (setq n (rem n 1000)) 100) (setq l (Cd100r  l)))
  23.       (repeat (/ (setq n (rem n  100))  10) (setq l (Cd10r   l)))
  24.       (repeat (/ (setq n (rem n   10))   4) (setq l (cddddr  l)))
  25.       (repeat (rem n 4)                     (setq l (cdr     l)))
  26.       l
  27.     )
  28.     ;
  29.     (defun ALE_List_LastN (n l)
  30.       (ALE_List_NthCdr (- (length l) n) l)
  31.     )
  32.     (defun ALE_List_FirstN (n l)
  33.       (reverse (ALE_List_NthCdr (- (length l) n) (reverse l)))
  34.     )
  35.     ;
  36.     (defun Cd10r (l)
  37.       (cddddr(cddddr(cddr l)))
  38.     )
  39.     (defun Cd100r (l)
  40.       (cddddr(cddddr(cddddr(cddddr l)))))))))))))))))))))))))
  41.     )
  42.     (defun Cd1000r (l)
  43.       (cddddr(cddddr(cddddr(cddddr(cddddr l))))))))))))
  44.       )))))))))))))))))))))))))))))))))))))))))))))))))
  45.       )))))))))))))))))))))))))))))))))))))))))))))))))
  46.       )))))))))))))))))))))))))))))))))))))))))))))))))
  47.       )))))))))))))))))))))))))))))))))))))))))))))))))
  48.       ))))))))))))))))))))))))))))))))))))))))))
  49.     )
  50.
  51.     (setq pos (fix (/ (setq len (length l)) 2.0)))
  52.     (setq l1 (ALE_List_FirstN (- len pos) l))
  53.     (setq l2 (ALE_List_LastN pos l))
  54.
  55.     (cond
  56.       ( (and l1 l2)
  57.         (setq a1 (vl-some (function (lambda ( aa ) (setq al1 (cons aa al1)) (if (vl-every (function (lambda ( xx ) (apply f (list aa xx)))) (append (cdr al1) (setq l1 (cdr l1)))) aa))) l1))
  58.         (setq a2 (vl-some (function (lambda ( aa ) (setq al2 (cons aa al2)) (if (vl-every (function (lambda ( xx ) (apply f (list aa xx)))) (append (cdr al2) (setq l2 (cdr l2)))) aa))) l2))
  59.         (if (apply f (list a1 a2))
  60.           a1
  61.           a2
  62.         )
  63.       )
  64.       ( t
  65.         (car l)
  66.       )
  67.     )
  68.   )
  69.
  70.   ;;; (car-sort '(2 4 1 3 5 1) '<) => 1, (1 belongs to both l1 and l2) but generally it would be nil if single list processing, so better is '<= than '<
  71.   ;;; (car-sort '(2 4 1 3 5 1) '<=) => 1
  72.
  73.   (setq l (atoms-family 1))
  74.   (setq t0 (car (_vl-times)))
  75.   (repeat 10
  76.     (car-sort-old l '(lambda ( a b ) (<= (strlen a) (strlen b))))
  77.   )
  78.   (setq t1 (car (_vl-times)))
  79.   (prompt "\nElapsed time for (car-sort-old) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  80.   (setq t0 (car (_vl-times)))
  81.   (repeat 10
  82.     (car-sort-new l '(lambda ( a b ) (<= (strlen a) (strlen b))))
  83.   )
  84.   (setq t1 (car (_vl-times)))
  85.   (prompt "\nElapsed time for (car-sort-new) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  86.   (setq t0 (car (_vl-times)))
  87.   (repeat 10
  88.     (car (vl-sort l '(lambda ( a b ) (<= (strlen a) (strlen b)))))
  89.   )
  90.   (setq t1 (car (_vl-times)))
  91.   (prompt "\nElapsed time for (car (vl-sort)) : ") (princ (rtos (- t1 t0) 2 20)) (prompt " milliseconds...")
  92.   (princ)
  93. )
  94.
  95. ;|
  96. Command: TEST
  97. Elapsed time for (car-sort-old) : 392688.0000000000 milliseconds...
  98. Elapsed time for (car-sort-new) : 52968.99999999999 milliseconds...
  99. Elapsed time for (car (vl-sort)) : 1406.000000000000 milliseconds...
  100. |;
  101.
M.R. on Youtube
« Reply #13 on: May 27, 2020, 10:59:18 AM »
Confused! I thought we weren't supposed to iterate (I'm not even sure how you would modify a list in any language I know without iteration of some kind).
ribarm
« Reply #14 on: May 27, 2020, 11:11:12 AM »
  5.    )
  6.    rtn
  7. )
Lee I see your point, I guess you're right... I was carried with my (vl-some) - (vl-every) solution from the first time I constructed (car-sort)... I haven't checked your version in comparison to (car (vl-sort)), but I believe it should perform the quickest... I'll check it once again...
M.R. on Youtube
