Author Topic: Breakpoints in forms - Bricscad  (Read 1501 times)
Bogy
  • Mosquito
« on: May 25, 2020, 10:00:57 AM »
Hello,
The code stop at breakpoints but I cannot debug:
"Your app has entered a break state, but no code is currently executing that is supported by the selected debug engine ..."
I've already tried:
 - Application.ShowModalDialog vs form.ShowDialog
 - to add useLegacyV2RuntimeActivationPolicy=false/true in app.config
 - NEXTFIBERWORLD - unknown in BricsCAD
How do you debug c# forms in Bricsacd?
Thank you,
Bogdan Sintoma
Atook
  • AKA Tim
Re: Breakpoints in forms - Bricscad
« Reply #1 on: May 25, 2020, 03:30:10 PM »
I'm curious to see if anyone has a solution. I had the same issue, and have just been doing my form debugging in AutoCAD. Either that or debug.writeline statements. :)
CADbloke
  • Crash Test Dummy
« Reply #2 on: May 26, 2020, 02:26:37 AM »
check your debug settings around "Just my code" ??
Bogy
  • Mosquito
« Reply #3 on: May 26, 2020, 02:44:19 AM »
Thanks for the suggestion, I changed but the same thing happens.
Note: in Modules - the dll has the status for User code = Yes (+ Symbols loaded).
Kind regards,
Bogdan
