Author Topic: Help with a lisp  (Read 2090 times)
PM
Help with a lisp
« on: May 25, 2020, 05:05:42 AM »
Hi .I am using this code to export to csv coordinates from autocad and then i use this csv file to upload data to my total station. The points i use is block attribiutes . Some of the have "ELEV" tag and same not. Some times the "ELEV" have elevetion and some tines is empty. I want  if "ELEV" is empty or does not exist to put 0.00 in the csv file. Can any one help ? Thanks
  1. (defun c:IDXPXYZ ( / *error* del des ent idx lst obj ord out rtn sel )
  2.
  3.
  4.     (defun *error* ( msg )
  5.         (if (= 'file (type des))
  6.             (close des)
  7.         )
  8.         (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
  9.             (princ (strcat "\nError: " msg))
  10.         )
  11.         (princ)
  12.     )
  13.
  14.     (setq ord '("POINT" POINT-X POINT-Y "ELEV" )
  15.           out  (LM:uniquefilename (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname))) ".csv")
  16.           del  ","
  17.     )
  18.     (if (setq sel (ssget '((0 . "INSERT") (66 . 1))))
  19.         (if (setq des (open out "w"))
  20.             (progn
  21.                 (repeat (setq idx (sslength sel))
  22.                     (setq ent (ssname sel (setq idx (1- idx)))
  23.                           obj (vlax-ename->vla-object ent)
  24.                     )
  25.                     (setq lst
  26.                         (append
  27.                             (mapcar '(lambda ( a b ) (cons a (rtos b)))
  28.                                '(point-x point-y point-z)
  29.                                 (trans (cdr (assoc 10 (entget ent))) ent 0)
  30.                             )
  31.                             (mapcar '(lambda ( x ) (cons (strcase (vla-get-tagstring x)) (vla-get-textstring x)))
  32.                                 (append
  33.                                     (vlax-invoke obj 'getattributes)
  34.                                     (vlax-invoke obj 'getconstantattributes)
  35.                                 )
  36.                             )
  37.                         )
  38.                     )
  39.                   (setq rtn (cons (vl-remove 'nil (mapcar '(lambda ( x ) (cdr (assoc x lst))) ord)) rtn))
  40.                 )
  41.       (foreach idx (LM:alphanumsort-i (mapcar 'car rtn))
  42.       ;(write-line (LM:lst->str (nth idx rtn) del) des)
  43.       (write-line (vl-string-translate "Σ;Τ;Κ" "S;T;K" (lm:lst->str (nth idx rtn) del)) des) ; HERE CONVERT SOME GREEK LETERS TO ENGLISH CHARACTERS PLEASE DONT CHANGE IT !!!!
  44.    )
  45.                 (setq des (close des))
  46.             )
  47.             (princ (strcat "\nUnable to open file: \"" out "\" for writing."))
  48.         )
  49.     )
  50.     (princ)
  51. )
  52.
  53. ;; List to String  -  Lee Mac
  54. ;; Concatenates each string in a list, separated by a given delimiter
  55.
  56. (defun LM:lst->str ( lst del )
  57.     (if (cdr lst)
  58.         (strcat (car lst) del (LM:lst->str (cdr lst) del))
  59.         (car lst)
  60.     )
  61. )
  62.
  63. ;; Unique Filename  -  Lee Mac
  64. ;; Returns a unique filename for a given path & file extension
  65.
  66. (defun LM:uniquefilename ( pth ext / fnm tmp )
  67.     (if (findfile (setq fnm (strcat pth ext)))
  68.         (progn
  69.             (setq tmp 1)
  70.             (while (findfile (setq fnm (strcat pth "(" (itoa (setq tmp (1+ tmp))) ")" ext))))
  71.         )
  72.     )
  73.     fnm
  74. )
  75.
  76. ;; Alphanumerical Sort-i  -  Lee Mac
  77. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices.
  78.
  79. (defun LM:alphanumsort-i ( lst )
  80.     (vl-sort-i (mapcar 'LM:splitstring lst)
  81.         (function
  82.             (lambda ( a b / x y )
  83.                 (while
  84.                     (and
  85.                         (setq x (car a))
  86.                         (setq y (car b))
  87.                         (= x y)
  88.                     )
  89.                     (setq a (cdr a)
  90.                           b (cdr b)
  91.                     )
  92.                 )
  93.                 (cond
  94.                     (   (null x) b)
  95.                     (   (null y) nil)
  96.                     (   (and (numberp x) (numberp y)) (< x y))
  97.                     (   (numberp x))
  98.                     (   (numberp y) nil)
  99.                     (   (< x y))
  100.                 )
  101.             )
  102.         )
  103.     )
  104. )
  105.
  106. ;; Split String  -  Lee Mac
  107. ;; Splits a string into a list of text and numbers
  108.
  109. (defun LM:splitstring ( str )
  110.     (
  111.         (lambda ( l )
  112.             (read
  113.                 (strcat "("
  114.                     (vl-list->string
  115.                         (apply 'append
  116.                             (mapcar
  117.                                 (function
  118.                                     (lambda ( a b c )
  119.                                         (cond
  120.                                             (   (or (= 34 b) (= 92 b))
  121.                                                 (list 32 34 92 b 34 32)
  122.                                             )
  123.                                             (   (or (< 47 b 58)
  124.                                                    ;(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  125.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  126.                                                 )
  127.                                                 (list b)
  128.                                             )
  129.                                             (   (list 32 34 b 34 32))
  130.                                         )
  131.                                     )
  132.                                 )
  133.                                 (cons nil l) l (append (cdr l) '(( )))
  134.                             )
  135.                         )
  136.                     )
  137.                     ")"
  138.                 )
  139.             )
  140.         )
  141.         (vl-string->list str)
  142.     )
  143. )
  144.
  145.
  146.
  147.
  148.
  149.
Re: Help with a lisp
« Reply #1 on: May 25, 2020, 05:43:26 AM »
Change:
  1. (setq rtn (cons (vl-remove 'nil (mapcar '(lambda ( x ) (cdr (assoc x lst))) ord)) rtn))
To:
  1. (setq rtn (cons (mapcar '(lambda ( x ) (cond ((cdr (assoc x lst))) ("0.00"))) ord) rtn))
(Original source here & here)
PM
« Reply #2 on: May 25, 2020, 12:06:44 PM »
Hi Lee Mac. I did the change but when "ELEV" does not exist add 0.00 but when the "ELEV" exist and is empty didn't add 0.00. Can you help ? Thanks
  2.
  3.
  6.             (close des)
  7.         )
  10.         )
  11.         (princ)
  12.     )
  13.
  16.           del  ","
  17.     )
  20.             (progn
  24.                     )
  25.                     (setq lst
  26.                         (append
  30.                             )
  32.                                 (append
  35.                                 )
  36.                             )
  37.                         )
  38.                     )
  39.                   ;(setq rtn (cons (vl-remove 'nil (mapcar '(lambda ( x ) (cdr (assoc x lst))) ord)) rtn))
  40.                    (setq rtn (cons (mapcar '(lambda ( x ) (cond ((cdr (assoc x lst))) ("0.00"))) ord) rtn))
  41.                 )
  42.       (foreach idx (LM:alphanumsort-i (mapcar 'car rtn))
  43.       ;(write-line (LM:lst->str (nth idx rtn) del) des)
  44.       (write-line (vl-string-translate "&#931;;&#932;;&#922;" "S;T;K" (lm:lst->str (nth idx rtn) del)) des)
  45.    )
  46.                 (setq des (close des))
  47.             )
  48.             (princ (strcat "\nUnable to open file: \"" out "\" for writing."))
  49.         )
  50.     )
  51.     (princ)
  52. )
  53.
  54. ;; List to String  -  Lee Mac
  55. ;; Concatenates each string in a list, separated by a given delimiter
  56.
  57. (defun LM:lst->str ( lst del )
  58.     (if (cdr lst)
  59.         (strcat (car lst) del (LM:lst->str (cdr lst) del))
  60.         (car lst)
  61.     )
  62. )
  63.
  64. ;; Unique Filename  -  Lee Mac
  65. ;; Returns a unique filename for a given path & file extension
  66.
  67. (defun LM:uniquefilename ( pth ext / fnm tmp )
  68.     (if (findfile (setq fnm (strcat pth ext)))
  69.         (progn
  70.             (setq tmp 1)
  71.             (while (findfile (setq fnm (strcat pth "(" (itoa (setq tmp (1+ tmp))) ")" ext))))
  72.         )
  73.     )
  74.     fnm
  75. )
  76.
  77. ;; Alphanumerical Sort-i  -  Lee Mac
  78. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices.
  79.
  80. (defun LM:alphanumsort-i ( lst )
  81.     (vl-sort-i (mapcar 'LM:splitstring lst)
  82.         (function
  83.             (lambda ( a b / x y )
  84.                 (while
  85.                     (and
  86.                         (setq x (car a))
  87.                         (setq y (car b))
  88.                         (= x y)
  89.                     )
  90.                     (setq a (cdr a)
  91.                           b (cdr b)
  92.                     )
  93.                 )
  94.                 (cond
  95.                     (   (null x) b)
  96.                     (   (null y) nil)
  97.                     (   (and (numberp x) (numberp y)) (< x y))
  98.                     (   (numberp x))
  99.                     (   (numberp y) nil)
  100.                     (   (< x y))
  101.                 )
  102.             )
  103.         )
  104.     )
  105. )
  106.
  107. ;; Split String  -  Lee Mac
  108. ;; Splits a string into a list of text and numbers
  109.
  110. (defun LM:splitstring ( str )
  111.     (
  112.         (lambda ( l )
  113.             (read
  114.                 (strcat "("
  115.                     (vl-list->string
  116.                         (apply 'append
  117.                             (mapcar
  118.                                 (function
  119.                                     (lambda ( a b c )
  120.                                         (cond
  121.                                             (   (or (= 34 b) (= 92 b))
  122.                                                 (list 32 34 92 b 34 32)
  123.                                             )
  124.                                             (   (or (< 47 b 58)
  125.                                                    ;(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  126.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  127.                                                 )
  128.                                                 (list b)
  129.                                             )
  130.                                             (   (list 32 34 b 34 32))
  131.                                         )
  132.                                     )
  133.                                 )
  134.                                 (cons nil l) l (append (cdr l) '(( )))
  135.                             )
  136.                         )
  137.                     )
  138.                     ")"
  139.                 )
  140.             )
  141.         )
  142.         (vl-string->list str)
  143.     )
  144. )
  145.
  146.
  147.
  148.
« Reply #3 on: May 25, 2020, 12:47:00 PM »
Change:
To:
  1. (setq rtn (cons (mapcar '(lambda ( x / v ) (if (and (setq v (cdr (assoc x lst))) (/= "" v)) v "0.00")) ord) rtn))
PM
« Reply #4 on: May 25, 2020, 04:19:24 PM »
Thank you Lee Mac
PM
« Reply #5 on: May 26, 2020, 03:14:38 AM »
Hi Lee Mac. Is it possible not export data for the points with the tag ¨POINT¨ empty ?
« Reply #6 on: May 26, 2020, 01:42:47 PM »
The program starts to lose it's generic applicability when we start hard-coding criteria for specifc tags/values, but here you go:
Change:
To:
  1. (if (assoc "POINT" lst)
  2.     (setq rtn (cons (mapcar '(lambda ( x / v ) (if (and (setq v (cdr (assoc x lst))) (/= "" v)) v "0.00")) ord) rtn))
  3. )
PM
« Reply #7 on: May 26, 2020, 07:32:42 PM »
Hi Lee Mack. Did the update but i didn't see any difference. I ask if "point" is empty don't export the coordinates. With this update export the coordinates but ass 0.00 in the empty tag. Can you fix it. Thanks
  2.
  3.
  6.             (close des)
  7.         )
  10.         )
  11.         (princ)
  12.     )
  13.
  16.           del  ","
  17.     )
  20.             (progn
  24.                     )
  25.                     (setq lst
  26.                         (append
  30.                             )
  32.                                 (append
  35.                                 )
  36.                             )
  37.                         )
  38.                     )
  40.                  ;(setq rtn (cons (mapcar '(lambda ( x ) (cond ((cdr (assoc x lst))) ("0.00"))) ord) rtn))
  41.                   ;(setq rtn (cons (mapcar '(lambda ( x / v ) (if (and (setq v (cdr (assoc x lst))) (/= "" v)) v "0.00")) ord) rtn))
  42.     (if (assoc "POINT" lst)
  43.         (setq rtn (cons (mapcar '(lambda ( x / v ) (if (and (setq v (cdr (assoc x lst))) (/= "" v)) v "0.00")) ord) rtn))
  44.     )
  45.                 )
  46.       (foreach idx (LM:alphanumsort-i (mapcar 'car rtn))
  47.       ;(write-line (LM:lst->str (nth idx rtn) del) des)
  48.       (write-line (vl-string-translate "&#931;;&#932;;&#922;" "S;T;K" (lm:lst->str (nth idx rtn) del)) des)
  49.    )
  50.                 (setq des (close des))
  51.             )
  52.             (princ (strcat "\nUnable to open file: \"" out "\" for writing."))
  53.         )
  54.     )
  55.     (princ)
  56. )
  57.
  58. ;; List to String  -  Lee Mac
  59. ;; Concatenates each string in a list, separated by a given delimiter
  60.
  61. (defun LM:lst->str ( lst del )
  62.     (if (cdr lst)
  63.         (strcat (car lst) del (LM:lst->str (cdr lst) del))
  64.         (car lst)
  65.     )
  66. )
  67.
  68. ;; Unique Filename  -  Lee Mac
  69. ;; Returns a unique filename for a given path & file extension
  70.
  71. (defun LM:uniquefilename ( pth ext / fnm tmp )
  72.     (if (findfile (setq fnm (strcat pth ext)))
  73.         (progn
  74.             (setq tmp 1)
  75.             (while (findfile (setq fnm (strcat pth "(" (itoa (setq tmp (1+ tmp))) ")" ext))))
  76.         )
  77.     )
  78.     fnm
  79. )
  80.
  81. ;; Alphanumerical Sort-i  -  Lee Mac
  82. ;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices.
  83.
  84. (defun LM:alphanumsort-i ( lst )
  85.     (vl-sort-i (mapcar 'LM:splitstring lst)
  86.         (function
  87.             (lambda ( a b / x y )
  88.                 (while
  89.                     (and
  90.                         (setq x (car a))
  91.                         (setq y (car b))
  92.                         (= x y)
  93.                     )
  94.                     (setq a (cdr a)
  95.                           b (cdr b)
  96.                     )
  97.                 )
  98.                 (cond
  99.                     (   (null x) b)
  100.                     (   (null y) nil)
  101.                     (   (and (numberp x) (numberp y)) (< x y))
  102.                     (   (numberp x))
  103.                     (   (numberp y) nil)
  104.                     (   (< x y))
  105.                 )
  106.             )
  107.         )
  108.     )
  109. )
  110.
  111. ;; Split String  -  Lee Mac
  112. ;; Splits a string into a list of text and numbers
  113.
  114. (defun LM:splitstring ( str )
  115.     (
  116.         (lambda ( l )
  117.             (read
  118.                 (strcat "("
  119.                     (vl-list->string
  120.                         (apply 'append
  121.                             (mapcar
  122.                                 (function
  123.                                     (lambda ( a b c )
  124.                                         (cond
  125.                                             (   (or (= 34 b) (= 92 b))
  126.                                                 (list 32 34 92 b 34 32)
  127.                                             )
  128.                                             (   (or (< 47 b 58)
  129.                                                    ;(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
  130.                                                     (and (= 46 b) (< 47 a 58) (< 47 c 58))
  131.                                                 )
  132.                                                 (list b)
  133.                                             )
  134.                                             (   (list 32 34 b 34 32))
  135.                                         )
  136.                                     )
  137.                                 )
  138.                                 (cons nil l) l (append (cdr l) '(( )))
  139.                             )
  140.                         )
  141.                     )
  142.                     ")"
  143.                 )
  144.             )
  145.         )
  146.         (vl-string->list str)
  147.     )
  148. )
  149.
  150.
  151.
  152.
BIGAL
  • 40 + years of using Autocad
« Reply #8 on: May 26, 2020, 09:50:07 PM »
I am sure Lee will answer but maybe here
(if (/= (strcase (vla-get-tagstring x)) "POINT")
PM
« Reply #9 on: May 27, 2020, 03:12:28 AM »
HI BIGAL .I try to add your code  but something is going wrong .Dont export anything !!!
« Reply #10 on: May 27, 2020, 10:34:23 AM »
Change:
  3. )
To:
  1. (if (and (setq pnt (assoc "POINT" lst)) (/= "" (cdr pnt)))
  3. )
PM
« Reply #11 on: May 27, 2020, 02:06:11 PM »
Thank you Lee Mac and BIGAL
