Author Topic: dwg shortcut on different versions of AutoCAD  (Read 2721 times)
dubb
« on: May 21, 2020, 04:46:29 PM »
I want to create a dwg shortcut that executes a script. I can only find examples of Target strings where it needs to contain the exact location of acad.exe
Here is an example of a Target string that works.
"C:\Program Files\Autodesk\AutoCAD 2018\acad.exe" /t "\\server\cad\00_Templates\blank.dwg" /b "\\server\cad\10_CAD Support\Scripts\foo-script"
Is there a way to edit the Target string so that I don't need to define the exact location of acad.exe?
I tried this. It didn't work.
Re: dwg shortcut on different versions of AutoCAD
« Reply #1 on: May 21, 2020, 05:06:13 PM »
Not exactly sure what you're asking but shouldn't this need the file extension to work?
"\\server\cad\10_CAD Support\Scripts\foo-script.scr"
dubb
« Reply #2 on: May 21, 2020, 05:21:18 PM »
Surprisingly it works with or without the .scr file extension.
I was thinking about adding a cmd string to access the registry to get the default acad.exe directory followed by
dubb
« Reply #3 on: May 21, 2020, 07:07:33 PM »
I tried loading the script using "command script". Still doesn't work.
"\\server\cad\00_Templates\blank.dwg" (command "SCRIPT" "\\\\server\\cad\\10_CAD Support\\Scripts\\foo-script.scr")
« Reply #4 on: May 22, 2020, 12:09:21 AM »
Are you adding this to the autocad shortcut? Not sure where you're going with the command ?
dubb
« Reply #5 on: May 22, 2020, 01:10:48 PM »
Its a shortcut for a dwg file. Not a shortcut for the autocad program itself.
BIGAL
  • 40 + years of using Autocad
