I have a routine to do ducts. It works fine everywhere but in the x,-y quad. I was hoping someone could tell me what is wrong.
(defun c:turn45 (/ SS1 SS2 SS3 SS4 1st_line line_1_info 2nd_line line_2_info 3rd_line line_3_info 4th_line line_4_info vertex_1 vertex_2 tempvar angle_1 angle_2 vertexangle in_angle pt1 pt2 vertexlength perp two_pi mid_1 mid_2); Multi-Angle Elbow
(command "undo" "begin")
(dc_store_variables) ;save current sys settings
(setq ss1 (ssadd)) ;SELECT SET HOLDER FOR FIRST INNER DUCT LINE
(setq ss2 (ssadd)) ;SELECT SET HOLDER FOR SECOND INNER DUCT LINE
(setq ss3 (ssadd)) ;SELECT SET HOLDER FOR FIRST OUTER DUCT LINE
(setq ss4 (ssadd)) ;SELECT SET HOLDER FOR SECOND OUTER DUCT LINE
(setq two_pi (* pi 2))
;SELECT INNER LINES AND FILLET
(setvar "osmode" 0)
(setvar "FILLETRAD" 0)
(setq 1st_line (entsel "\nPick first inner line for elbow: "))
(ssadd (car 1st_line) ss1)
(setq mid_1 (Osnap (Cadr 1st_line) "NEA"))
(setq line_1_info (entget (car 1st_line)))
(setq 2nd_line (entsel "\nPick second inner line for elbow: "))
(ssadd (car 2nd_line) ss2)
(setq mid_2 (Osnap (Cadr 2nd_line) "NEA"))
(setq line_2_info (entget (car 2nd_line)))
(setq 3rd_line (entsel "\nPick first outer line for elbow: "))
(ssadd (car 3rd_line) ss3)
(setq line_3_info (entget (car 3rd_line)))
(setq 4th_line (entsel "\nPick second outer line for elbow: "))
(ssadd (car 4th_line) ss4)
(setq line_4_info (entget (car 4th_line)))
;FILLET LINES
(command "_.fillet" 1st_line 2nd_line)
(command "_.fillet" 3rd_line 4th_line)
;ERASE SELECTION SETS
(setq ss1 nil)
(setq ss2 nil)
(setq ss3 nil)
(setq ss4 nil)
;RESET SS1 FOR FUTURE USE
(setq ss1 (ssadd))
;FIND INTERSECTION POINTS OF LINES
(setq vertex_1 (inters (cdr (assoc 10 line_1_info)) (cdr (assoc 11 line_1_info)) (cdr (assoc 10 line_2_info)) (cdr (assoc 11 line_2_info)) nil))
(setq vertex_2 (inters (cdr (assoc 10 line_3_info)) (cdr (assoc 11 line_3_info)) (cdr (assoc 10 line_4_info)) (cdr (assoc 11 line_4_info)) nil))
;DRAW LINE CONNECTING VERTICES
(command "LINE" vertex_1 vertex_2 "")
(command "matchprop" 1st_line (entlast) "")
;GET ANGLES OF FIRST LINE AND SECOND LINE AND FIND DIFFERENCE
(setq angle_1 (angle vertex_1 mid_1))
(if (= angle_1 0) ;IF EITHER ANGLE IS ZERO, SET TO 2XPI
(setq angle_1 two_pi)
);ENDIF
(setq angle_2 (angle vertex_1 mid_2))
(if (= angle_2 0) ;IF EITHER ANGLE IS ZERO, SET TO 2XPI
(setq angle_2 two_pi)
);ENDIF
(setq in_angle (abs(- angle_1 angle_2)))
(if (> in_angle pi) ;IF ANGLE > 180 DEG,
(setq in_angle (- two_pi in_angle)) ;SET ANGLE TO 360 - ANGLE
);ENDIF
;CALCULATE ANGULAR OFFSET FROM VERTEX LINE
(setq vertexangle (angle vertex_1 vertex_2))
(setq offangle (/ (- pi in_angle) 2)) ;(PI - INTERIOR ANGLE)/2 = ANGULAR OFFSET FROM VERTEX LINE
;CALCULATE LENGTH OF PERP LINE
(setq vertexlength (distance vertex_1 vertex_2))
(setq perp (* (cos offangle) vertexlength)) ;GET LENGTH OF PERP LINE
;SET START POINT FOR 1ST PERPENDICULAR LINE
(setq pt1 (polar vertex_1 angle_1 2))
;SET END POINT FOR 1ST PERPENDICULAR LINE
((> angle_1 angle_2) (setq pt2 (polar pt1 (- vertexangle offangle) perp)))
((> angle_2 angle_1) (setq pt2 (polar pt1 (+ vertexangle offangle) perp)))
(t nil)
);END CONDITIONAL
(command "LINE" pt1 pt2 "")
(ssadd (entlast) ss1)
(command "MIRROR" ss1 "" vertex_1 vertex_2 "")
(setq ss1 nil)
;RESTORE SYSTEM VARIABLES
(dc_restore_variables) ;restore current sys settings
(setvar "FILLETRAD" filrad)
(command "undo" "end")
