Author Topic: LISP help : Change Layer Lisp modifications  (Read 1240 times)
jrr114
« on: May 18, 2020, 11:10:54 AM »
I have a LISP routine that needs modifications.  I am not at all literate in this language.  I used the routine at a previous location.   Now I am somewhere else and the layer system is different.  The command would take objects from an existing layer to a demolition layer, new layer to demolition layer, new layer to existing layer and so on.  You will also see reference to Rev A and Rev C, that is no longer used.  I can provide the current file to be modified.  Can anyone help me?  Thanks in advance.
tombu
  • ByLayer=>Not0
Re: LISP help : Change Layer Lisp modifications
« Reply #1 on: May 18, 2020, 11:42:48 AM »
It would be easier to us Layer Translater http://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-83CFD677-78F3-492F-A5A3-5A0197D2FA2C
commands which is built int AutoCAD.
Tom Beauford P.S.M.
jrr114
« Reply #2 on: May 18, 2020, 12:07:54 PM »
Thanks for this suggestion.  I will look into this command.
Stay well and stay safe.
