CAD Forums > Land Lubber / Geographically Positioned
mappolygonedit - Remove a vertex from a Mappolygon
(1/1)
Peter2:
Acad Map 3D 2018 German
"mappolygonedit" should be based on the command "pedit", and yes - it behaves similiar, and I get the command-offers "Next / Previous / Insert / Move / Quit" for vertex.
But where is the the command for "remove vertex"?
Special Challenge
a) In classic "Pedit" it should be "_straighten", but this command does not work for me on simple plines.
b) I have to use the classic command line, because I get no "grips - context menu" on this polygon. Because it is a "ring" with an inner hole ...
Rather confused ...
Peter
Peter2:
I hope "mapmpedit" will do it ...
Navigation
[0] Message Index
Go to full version
