Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Modify system variable on a closed drawing ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Modify system variable on a closed drawing ? (Read 1633 times)
latour_g
Newt
on:
May 13, 2020, 10:26:54 AM »
Hi there,
I have done a few things on closed drawings but I have never changed a system variable, specificaly Proxygraphics. I have search to see if it's doable but found nothing.
So I'm asking here, is it doable to do so ?
Thnak you
Last Edit: May 14, 2020, 08:52:14 AM by latour_g
Logged
WOWENS
Newt
Re: Modify system variable on a closed drawing ?
Reply #1 on:
May 27, 2020, 02:47:04 PM »
might give this a try
Code - vb.net:
[Select]
Private
Sub
test2
MyDwg
As
String
If
IsFileLocked
New
IO
FileInfo
MyDwg
False
Then
Using
db
As
New
Database
False
True
db
ReadDwgFile
MyDwg, IO
FileShare
ReadWrite
False
Dim
workDb
As
Database
HostApplicationServices
WorkingDatabase
If
WorkingDatabase
db
Then
WorkingDatabase
db
End
If
Using
MyTrans
As
Transaction
db
TransactionManager
StartTransaction
Try
If
db
Orthomode
True
Then
db
Orthomode
False
Else
db
Orthomode
True
End
If
db
Saveproxygraphics
0
MyTrans
Commit
db
SaveAs
MyDwg, DwgVersion
Current
Catch
MyTrans
Abort
db
CloseInput
True
Application
DocumentManager
MdiActiveDocument
Editor
WriteMessage
vbCrLf
"Could Not Save Drawing "
MyDwg
Finally
If
WorkingDatabase
workDb
Then
WorkingDatabase
workDb
End
If
End
Try
End
Using
db
Dispose
End
Using
Else
Application
DocumentManager
MdiActiveDocument
Editor
WriteMessage
vbCrLf
"Could Not Open Drawing "
MyDwg
End
If
End
Sub
Private
Function
IsFileLocked
ByVal
file
As
IO
FileInfo
As
Boolean
Dim
stream
As
IO
FileStream
Nothing
Try
stream
file
Open
IO
FileMode
Open
, IO
FileAccess
ReadWrite
, IO
FileShare
None
Catch
Return
True
End
Try
If
Not
stream
Is
Nothing
Then
stream
Close
End
If
Return
False
End
Function
EDIT (John): Added code tags.
Last Edit: May 27, 2020, 03:35:37 PM by John Kaul (Se7en)
Logged
Jeff H
Needs a day job
Reply #2 on:
May 28, 2020, 01:43:33 PM »
As Wowens showed if is a variable stored in the drawing and should be a property of Database object then you will have to open it with ReadDwgFile.
For system wide variables you can edit with Application object or directly edit registry which probably would not be ideal.
Logged
--> Donate to TheSwamp <--
latour_g
Newt
Reply #3 on:
June 03, 2020, 03:00:23 PM »
Thanks to both of you ! I will try it soon and let you know i it'S work !
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
