Author Topic: [AUTOCAD MEP] _AECPROPERTYRENUMBERDATA with Fence Selection  (Read 3671 times)
jtm2020hyo
Is there a way to use _AECPROPERTYRENUMBERDATA ( propertyrenumberdata ) selecting multiple objects with Fence or similar?
Hanauer
  • Mosquito
Re: [AUTOCAD MEP] _AECPROPERTYRENUMBERDATA with Fence Selection
« Reply #1 on: May 14, 2020, 01:06:22 PM »
One way that comes with AutoCAD MEP is unknown to me.
You can implement this through a plug-in and it is relatively easy.
Can reorder in order of selection of objects, by coordinates, in order that objects were inserted in the drawing, reorder one by one ( Implemented by MEP), or other ways. Implement as needed.
jtm2020hyo
« Reply #2 on: May 14, 2020, 07:14:47 PM »
I was thinking in create another property set data with values incremental and another tag, but your method sounds interesting. Might explain us how to reinsert objects or reorde in order of selection of objects, please?
Hanauer
  • Mosquito
« Reply #3 on: May 15, 2020, 08:46:26 AM »
Basic sample for manipulate the AutoIncrementDataType of PropertySet using SortedDictionary.
In a windows form dialog:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
// AutoCAD References
using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcException = Autodesk.AutoCAD.Runtime.Exception;
using ObjectId = Autodesk.AutoCAD.DatabaseServices.ObjectId;
using ObjectIdCollection = Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection;
// AutoCAD ACA/MEP References
using Autodesk.Aec.DatabaseServices;
using Autodesk.Aec.PropertyData.DatabaseServices;
using AecDb = Autodesk.Aec.DatabaseServices;
using AecPropDb = Autodesk.Aec.PropertyData.DatabaseServices;
namespace Gh.Aec.PropertyData
    public partial class GhAecPropertyDataSortForm : Form
        Document m_doc;
        Database m_db;
        GhAecPropertyDataSortSettings m_settings;
        public GhAecPropertyDataSortForm()
            InitializeComponent();
            m_doc = AcApp.DocumentManager.MdiActiveDocument;
            m_db = m_doc.Database;
            m_settings = new GhAecPropertyDataSortSettings(m_db);
            m_settings.Read();
            FillCombos();
        private void btnSort_Click(object sender, EventArgs e)
            SortedDictionary<int, ObjectId> propSetIds = new SortedDictionary<int, ObjectId>();
            string propSetDefName = cmbPropertySet.SelectedItem.ToString();
            string propName = cmbProperty.SelectedItem.ToString();
            this.Hide();
            CollectPropertySetData(propSetIds, propSetDefName, propName);
            Sort(propSetIds, propSetDefName, propName);
        private void CollectPropertySetData(SortedDictionary<int, ObjectId> propSetIds, string propSetDefName, string propName)
            ObjectId psdId = ObjectId.Null;
            AcDb.DBObject dbobj;
            PropertyValueUnitPair pvup = new PropertyValueUnitPair();
            psdId = GhAecPropertySetHelper.GetPropertySetDefinitionIdByName(propSetDefName, m_db);
            using (Transaction tr = m_db.TransactionManager.StartTransaction())
                BlockTable bt = tr.GetObject(m_db.BlockTableId, OpenMode.ForRead, false) as BlockTable;
                BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead, false) as BlockTableRecord;
                foreach (ObjectId id in btr)
                    try
                        dbobj = tr.GetObject(id, OpenMode.ForRead, false, false);
                        ObjectId psId = PropertyDataServices.GetPropertySet(dbobj, psdId);
                        PropertySet ps = tr.GetObject(psId, OpenMode.ForRead) as PropertySet;
                        pvup = GhAecPropertySetHelper.GetValueFromPropertySetId(propName, psId, m_db);
                        propSetIds.Add((int)pvup.Value, psId);
                    catch
                tr.Commit();
        private void Sort(SortedDictionary<int, ObjectId> propSetIds, string propSetDefName, string propName)
            bool updated = false;
            int number = (int)nup1.Value;
            int incr = (int)nup2.Value;
            if (propSetIds.Count == 0)
                m_doc.Editor.WriteMessage(String.Format("\nNot found property set name {0} attached to entities in the drawing.", propSetDefName));
                return;
            // the transaction is the undo mark
            // one undo rollback all modifications bellow
                foreach (KeyValuePair<int, ObjectId> kvp in propSetIds)
                    if (number != kvp.Key)
                        updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, kvp.Value, number, tr);
                    number = number + incr;
                tr.Commit();
        private void FillCombos()
            List<string> lst = new List<string>();
            lst = GhAecPropertySetHelper.GetPropertySetDefinitionNamesWithAutoIncrementDataType(m_db);
            foreach (string name in lst)
                cmbPropertySet.Items.Add(name);
            if (cmbPropertySet.Items.Count > 0)
                if (m_settings.HasSettings())
                   int index = cmbPropertySet.FindString(m_settings.PropertySetDefinitionName);
                   if (index > 0)
                       cmbPropertySet.SelectedIndex = index;
                   else
                       cmbPropertySet.SelectedIndex = 0;
                else
        private void btnClose_Click(object sender, EventArgs e)
            this.Close();
        private void cmbPropertySet_SelectedIndexChanged(object sender, EventArgs e)
            cmbProperty.SelectedIndex = -1; // deseleciona os itens selecionados. Se tiver item selecionado clear() não remove ele
            cmbProperty.Items.Clear();
            lst = GhAecPropertySetHelper.GetAutoIncrementPropertyDefinitionNames(cmbPropertySet.SelectedItem.ToString(), m_db);
                cmbProperty.Items.Add(name);
            if (cmbProperty.Items.Count > 0)
                    int index = cmbProperty.FindString(m_settings.PropertyDefinitionAutoIncrementName);
                    if (index > 0)
                        cmbProperty.SelectedIndex = index;
                    else
                        cmbProperty.SelectedIndex = 0;
                else
            if (cmbPropertySet.SelectedIndex >= 0)
                m_settings.PropertySetDefinitionName = cmbPropertySet.SelectedItem.ToString();
        private void btnInsert_Click(object sender, EventArgs e)
            this.Hide();
            Insert(propSetIds, propSetDefName, propName);
        private void Insert(SortedDictionary<int, ObjectId> propSetIds, string propSetDefName, string propName)
            int start = (int)nup1.Value;
                return;
            if (!propSetIds.ContainsKey(start))
                m_doc.Editor.WriteMessage(String.Format("\nNot found {0} auto incremented integer in the property {1} of property set definition {2}.", start, propName, propSetDefName));
                return;
                    if (kvp.Key >= start)
                        updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, kvp.Value, kvp.Key + incr, tr);
                tr.Commit();
        private void MoveTo(SortedDictionary<int, ObjectId> propSetIds, string propSetDefName, string propName)
            int from = (int)nup1.Value;
            int to = (int)nup2.Value;
                return;
                updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, propSetIds[from], to, tr);
                while (propSetIds.ContainsKey(to) && to != from )
                    updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, propSetIds[to], ++to, tr);
                tr.Commit();
        private void Swap(SortedDictionary<int, ObjectId> propSetIds, string propSetDefName, string propName)
            int with = (int)nup2.Value;
                return;
            if (!propSetIds.ContainsKey(number))
                m_doc.Editor.WriteMessage(String.Format("\nNot found {0} auto incremented integer in the property {1} of property set definition {2}.", number, propName, propSetDefName));
                return;
            if (!propSetIds.ContainsKey(with))
                m_doc.Editor.WriteMessage(String.Format("\nNot found {0} auto incremented integer in the property {1} of property set definition {2}.", with, propName, propSetDefName));
                return;
                updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, propSetIds[number], with, tr);
                updated = GhAecPropertySetHelper.SetValueFromPropertySetId(propName, propSetIds[with], number, tr);
                tr.Commit();
        private void btnMoveTo_Click(object sender, EventArgs e)
            this.Hide();
            MoveTo(propSetIds, propSetDefName, propName);
        private void btnSwap_Click(object sender, EventArgs e)
            this.Hide();
            Swap(propSetIds, propSetDefName, propName);
        private void btnInsert_MouseHover(object sender, EventArgs e)
            lbl1.Text = "Number";
            lbl2.Text = "Increment";
            lbl2.Visible = true;
            nup2.Visible = true;
        private void btnSort_MouseHover(object sender, EventArgs e)
            lbl1.Text = "Start number";
            lbl2.Visible = false;
            nup2.Visible = false;
        private void btnMoveTo_MouseHover(object sender, EventArgs e)
            lbl1.Text = "From number";
            lbl2.Text = "to number";
        private void btnSwap_MouseHover(object sender, EventArgs e)
            lbl2.Text = "with number";
        private void GhAecSortPropertyDataForm_Load(object sender, EventArgs e)
        private void cmbProperty_SelectedIndexChanged(object sender, EventArgs e)
            if (cmbProperty.SelectedIndex >= 0)
                m_settings.PropertyDefinitionAutoIncrementName = cmbProperty.SelectedItem.ToString();
        private void GhAecSortPropertyDataForm_FormClosing(object sender, FormClosingEventArgs e)
            m_settings.Write();
Helper methods:
public static class GhAecPropertySetHelper
       public static List<string> GetPropertySetDefinitionNamesWithAutoIncrementDataType(Database db)
               DictionaryPropertySetDefinitions psdDict = new DictionaryPropertySetDefinitions(db);
               ObjectIdCollection psdIds = psdDict.Records;
               foreach (ObjectId id in psdIds)
                   PropertySetDefinition psdf = (PropertySetDefinition)tr.GetObject(id, OpenMode.ForRead, false, false);
                   PropertyDefinitionCollection pdc = psdf.Definitions;
                   foreach (PropertyDefinition pd in pdc)
                       if (pd.DataType == Autodesk.Aec.PropertyData.DataType.AutoIncrement)
                           lst.Add(psdf.Name);
                           break;
               tr.Commit();
           return lst;
       public static List<string> GetAutoIncrementPropertyDefinitionNames(string propSetDefName, Database db)
               if (psdDict.Has(propSetDefName, tr))
                    // Assign the return variable the ObjectId of the property set
                    psdId = psdDict.GetAt(propSetDefName);
                    PropertySetDefinition psdf = (PropertySetDefinition)tr.GetObject(psdId, OpenMode.ForRead, false, false);
                            lst.Add(pd.Name);
               tr.Commit();
           return lst;
       public static bool SetValueFromPropertySetId(string propName, ObjectId propSetId, Object value, Database db)
           bool findAny = false;
           int propSetDefId = 0;
           using (Transaction trans = db.TransactionManager.StartTransaction())
               try
                   PropertySet propSet = (PropertySet)trans.GetObject(propSetId, OpenMode.ForWrite, false, false);
                   propSetDefId = propSet.PropertyNameToId(propName);
                   if ((propSet.IsWriteEnabled))
                        propSet.SetAt(propSetDefId, value);
                       findAny = true;
               catch (AcException)
                   // most likely eKeyNotFound.
               trans.Commit();
           return findAny;
       public static ObjectId GetPropertySetDefinitionIdByName(string propSetDefName, Database db)
           // Create objectId to hold the property set objectId and
           // set the default value equal to null.
           AcDb.TransactionManager tm = db.TransactionManager;
           using (Transaction trans = tm.StartTransaction())
               // Create a Property Set Dictionary
               AecPropDb.DictionaryPropertySetDefinitions psdDict = new AecPropDb.DictionaryPropertySetDefinitions(db);
               // Check to see if the dictionary contains the name of the property set we are looking for
               if (psdDict.Has(propSetDefName, trans))
               } // End If Block
               trans.Commit();
           } // End Using Statement
           return psdId;
jtm2020hyo
« Reply #4 on: May 16, 2020, 03:25:56 AM »
Looks awesome.
Thank for your help.
jtm2020hyo
« Reply #5 on: February 22, 2022, 08:54:43 PM »
Excuse me, how could I update this to NET framework 4.8?
HOSNEYALAA
« Reply #6 on: August 08, 2022, 07:40:13 AM »
HI @Hanauer
Is it possible
Share a full project
I couldn't arrange it like you did, I made mistakes
Thank you
