Author Topic: Global change of font styles  (Read 2549 times)
Lonnie
« on: April 29, 2020, 10:41:03 AM »
I am looking into making a set of tools to bring autocad files into revit. One of the first things is to change the text to arial. I've tried a few ways to do it but nothing seems to work. Here is the latest.
(defun c:csf (/ doc sty)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq sty (vla-get-textstyles doc))
  (vlax-for s sty (vla-put-fontfile s "C:\\Windows\\Fonts\\arial.ttf"))
  (vlax-for w sty (vla-put-width w 1.0))
  (vla-regen doc acAllViewports)
My problem is when I run this the fonts change to the nearest arial not to arial.ttf. Most times it's Arial CYR but I've had it change to arial.shx even.
As always thanks.
Lonnie
tombu
  • ByLayer=>Not0
Re: Global change of font styles
« Reply #1 on: April 29, 2020, 10:45:09 AM »
Merge text styles (or change text styles)
https://www.theswamp.org/index.php?topic=17659.0
Tom Beauford P.S.M.
« Reply #2 on: April 29, 2020, 11:20:07 AM »
As always thanks.
Lonnie
Try this mod .. I ran into this a while back too.
  1. (defun c:csf (/ f doc)
  2.   (if (findfile (setq f (strcat (getenv "windir") "\\Fonts\\Arial.ttf")))
  3.     (progn
  4.         (vla-put-fontfile s f)
  5.         (vla-put-width s 1.0)
  6.         ;; RJP » 2020-04-29
  7.         (vla-setfont s "Arial" :vlax-false :vlax-false 0 34)
  8.       )
  9.       (vla-regen doc acallviewports)
  10.     )
  11.   )
  12.   (princ)
  13. )
Lonnie
« Reply #3 on: April 29, 2020, 11:23:39 AM »
Works at least in the first 4 dwg's.
Thank you.
« Reply #4 on: April 29, 2020, 11:29:54 AM »
Thank you.
You're welcome.  :-)
