Author Topic: ---={ Challenge }=--- Find inverse function  (Read 7476 times)
Re: ---={ Challenge }=--- Find inverse function
« Reply #15 on: April 27, 2020, 02:12:53 PM »
This is impossible in general.
i guess Marko just wants to know with what argument a function was called
As in: vl-bb-ref/set?
Not exactly... That among other things, but I really want inverse function of function...
Still very confusing!
VovKa
  • Ukraine
« Reply #16 on: April 27, 2020, 02:18:11 PM »
it is also possible that Marko has a compiled lisp and wants to know what is happening inside it during the execution
ribarm
  • Marko Ribar, architect
« Reply #17 on: April 27, 2020, 02:40:30 PM »
No, I have no particular needs... I just want this solved as challenge and like I said I often use formulas inside LISPS and I wanted to know is there a way to reverse formula... Not to bang my head by using arithmetics and algebra I just guessed that there must be simple way through LISP defuns and by using PC (AutoCAD)...
M.R. on Youtube
« Reply #18 on: April 27, 2020, 03:04:14 PM »
Not to bang my head by using arithmetics and algebra ...
If I understand what you're saying the arithmetics / algebra would instead be delegated to a non trivial, clever, auto heuristic function - authoring the adaptive arithmetics and algebra therein would dwarf the effort to write hundreds of specific 'inverse functions'.
tl;dr: While I salute the notion can't see it coming to fruition ... then again it's likely I don't understand the intent.
ribarm
« Reply #19 on: April 27, 2020, 03:42:05 PM »
With all respect to those that wrote inverse functions by using math or other techniques, I still can't imagine that with using PC there is no way to reverse operations of straight forward function... Simply if you have a=b+2, you have to write b=a-2... I imagine that for every input there is output in every formula... Isn't it true that every function with formula can be represented as curve in XY coordinate system... So can AutoCAD generate that curve and then just swap XY to YX and read that curve from YX as if it's function in XY (so formula is reversed)... Now outputs would become inputs and inputs outputs if we are to get values, but solution is just formula of that curve but in YX... In other words when you look it all just in XY, there is formula and curve and there should be formula for curve symetrical to function y=x... Shouldn't AutoCAD be capable of getting that curve function, or even there shouldn't even be need for getting formula - there is initial formula and corresponding Y^-1 (but no need for that - just normal Y function of curve is enough), so for every y coordinate there is x one read diractly from that curve...
M.R. on Youtube
VovKa
  • Ukraine
« Reply #20 on: April 27, 2020, 03:58:01 PM »
try it with a parabola :)
ribarm
« Reply #21 on: April 27, 2020, 04:02:25 PM »
With functions like (chr) - (ascii) the principle is the same just in list form built in initial function for ex. (chr)... For every number 65 there is "A" letter and opposite for every letter there is number - isn't that list already built-in (chr) function... So can list be reversed ((num letter) (65 "A") (85 "U") ...) and this is read as ((letter num) ("A" 65) ("U" 85) ...)... Basically we just need (defun invres ( chrlst ) (mapcar '(lambda ( x ) (list (cadr x) (car x))) chrlst))... (defun chrinv ( a ) (cadr (assoc a (invres chrlst))))
M.R. on Youtube
« Reply #22 on: April 27, 2020, 04:05:11 PM »
That would be a pain in the latus rectum.
Stefan
« Reply #23 on: April 27, 2020, 04:47:07 PM »
It's only possible if the function is bijective, that means for each x there is only one y and vice-versa. Linear functions are like this.
So you know the f(x) function (not really the expression of the function, but only it's output) and you want to solve the x in y=f(x) .
Plot the function as spline with (x, f(x)) points and draw a horizontal Xline at (0,y,0). If you are lucky and it intersect the plot, the inverse is the x coordinate of the intersection.
Of course, the spline is finite, from a,f(a) to b,f(b). If it doesn't intersect, change the interval.
Grrr1337
« Reply #24 on: April 27, 2020, 04:57:12 PM »
Similar thought here, if the returns are exponentially growing or decaying, pseudocode -
  1. (defun f ( a )
  2.   (* 0.25 (+ 10 (* a a a) (* 2 (+ 5 a))))
  3. )
  4.
  5.
  6. _$ (mapcar 'f '(1 2 3 4 5 6 7 8 9 10)) ; observation
  7. (5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0)
  8.
  9. (defun fE ( a )
  10.   ; replicate 'f as exponential
  11.   ; ..
  12. )
  13.
  14. _$ (mapcar 'fE '(1 2 3 4 5 6 7 8 9 10)) ; observation and modify till reaching the results of 'f
  15. (5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0)
  16.
  17. (defun fEinv ( b )
  18.   ; write out inverse exponential for 'fE
  19. )
  20.
  21. _$ (mapcar 'fEinv '(5.75 8.0 13.25 23.0 38.75 62.0 94.25 137.0 191.75 260.0))
  22. '(1 2 3 4 5 6 7 8 9 10)
This might be of help.
But I don't think this approach would handle 'parabola jumps' - for special cases like: (if (< 5 a 10) (setq a 1)).
The ultimate would be machine-learning approach, collecting all of the data and acting from there with a tremendous amounf of if statements.  :uglystupid2:
EDIT: I mean if you want to inverse something that you don't know how its defined, the first step would be to attempt to replicate the definition and then come-up with a inversion.
« Last Edit: April 27, 2020, 05:00:13 PM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
Grrr1337
« Reply #25 on: April 27, 2020, 05:53:22 PM »
Here is some initial code related to the above comment :
  1. (defun f ( a )
  3. )
  4.
  5. ;|
  6. (f 4.5)
  7. >> 30.0313 ; the result we're looking for
  8. (fooInv f 4.5 '(1 2 3 4 5 6 7 8 9 10))
  9. >> 29.6683
  10. (fooInv f 4.5 '(1 2 3 4.3 4.8 5 6 7 8 9 10))
  11. >> 29.9508
  12. (fooInv f 4.5 '(1 2 3 4 4.5 5 6 7 8 9 10)) ; here the actual 'b' arg is suppled for running, hence (f b) is invoked and that makes 'fooInv' pointless
  13. >> 30.0312 ; close enough
  14. _$ (fooInv f 4.5 '(1 4.5 100))
  15. >> 30.0313
  16. |;
  17. (defun fooInv ( f b args / L r )
  18.   (cond
  19.     ( (vl-some 'not (list f b args)) (prompt "\nInvalid arguments supplied.") )
  20.     (
  21.       (progn
  22.         (and
  23.           (not (vl-some (function (lambda (x) (equal b x 1e-4))) args))
  24.           (prompt
  25.             "\nThe argument 'b' is not contained within 'args',
  26.            \nwhich may lead to not enough accurate result
  27.            \nalthough that would make this sub useless."
  28.           )
  29.         ); and
  30.         nil
  31.       ); progn
  32.     )
  33.     ( (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (setq L (mapcar '(lambda (x) (list x (f x) 0)) args))))))
  34.       (prompt "\nThe supplied function 'f' errors out on some of the provided arguments.")
  35.     )
  36.     (
  37.       (vl-catch-all-apply
  38.         (function
  39.           (lambda ( / spl xl )
  40.             (and
  41.               (setq spl (AddSpline L))
  42.               (setq xl (AddXline (list (float b) 0.0 0.0)))
  43.               (setq r (cadr (vlax-invoke spl 'InterSectWith xl acExtendNone)))
  44.             )
  45.             (mapcar 'vla-Delete (list spl xl))
  46.           )
  47.         )
  48.       )
  49.     )
  50.   ); cond
  51.   r
  52. ); defun
  53.
  54.
  55.
  56.
  57. (defun AddSpline ( 3DPtLst / r )
  58.   (cond
  59.     ( (not (vl-consp 3DPtLst)) )
  60.     ( (not (vl-every 'vl-consp 3DPtLst)) )
  61.     ( (progn (setq 3DPtLst (mapcar '(lambda (x) (if (= 2 (length x)) (append x '(0.0)) x)) 3DPtLst)) nil) )
  62.     (
  63.       (setq r
  64.           (vlax-safearray-fill
  65.             (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length (apply 'append 3DPtLst)))))
  66.             (apply 'append 3DPtLst)
  67.           )
  68.           (vlax-3d-point '(0. 0. 0.))
  69.           (vlax-3d-point '(0. 0. 0.))
  70.         )
  71.       ); setq r
  72.     )
  73.   ); cond
  74.   r
  75. ); defun
  76.
  77. ; (AddXline (getpoint))
  78. (defun AddXline ( p )
  79.     p (mapcar '+ '(0.0 1.0 0.0) p)
  80.   )
  81. )
vevo.bg
« Reply #26 on: April 27, 2020, 10:03:32 PM »
> ("A" 65) ("U" 85)
That's an assocation list (or data structure). What's wrong with that? You don't need to reorder/reverse/clean/etc. the list at all; why would you?! The access to a list strucutre (via assoc, car, cdr, etc. is far, far faster then anything you could ever build). Frankly, people spend far too much time messing with lists; your functions should *NOT* care if the list is full of "nil" and/or "0's". And most times, your list doesn't need to be in ascending or alphabetical order; just let the built-in tools like ASSOC find them for you.
ribarm
« Reply #27 on: April 28, 2020, 12:44:48 AM »
@Grrr, very well coded... Thanks for your functions...
I actually modified it to represent fooInv like it should... (if you read my comment and Stefan's about inversion)
  1. (defun f ( a )
  3. )
  4.
  5. (defun _sin ( x / __sin k r ) ;; x - angle in radians
  6.
  7.   (defun __sin ( x n / factorial )
  8.
  9.     (defun factorial ( n )
  10.       (if (/= (float n) 1.0) (* (float n) (factorial (1- n))) 1.0)
  11.     )
  12.
  13.     ((if (= (rem n 2) 0) + -) (/ (expt x (1+ (* 2 n))) (factorial (1+ (* 2 n)))))
  14.   )
  15.
  16.   (setq k 0 r 0.0)
  17.   (while (<= (setq k (1+ k)) 200) ;; Tyler order - 200 expressions
  18.     (setq r (+ r (__sin x k)))
  19.   )
  20.   (+ x r)
  21. )
  22.
  23. ;|
  24. (f 1)
  25. >> 5.75 ; minimal value of chosen interval
  26. (f 4.5)
  27. >> 30.0313 ; the result we're looking for
  28. (f 10)
  29. >> 260.0 ; maximal value of chosen interval
  30. (fooInv f 30.0313) ; a=1, b=10, n=9 ['(1 2 3 4 5 6 7 8 9 10)]
  31. >> 4.5231
  32. (fooInv f 30.0313) ; a=1, b=10, n=18 ['(1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 8 8.5 9 9.5 10)] ; here the actual 'b' arg is suppled for running, hence (f b) is invoked and that makes 'fooInv' near exact function
  33. >> 4.5 ; exactly
  34. (fooInv f 30.0313) ; a=1, b=8, n=2 ['(1 4.5 8)]
  35. >> 4.50001 ; close enough
  36.
  37. Using fooInv between min and max values of looking interval
  38. (fooInv f 50.0) ; a=1, b=10, n=9 ['(1 2 3 4 5 6 7 8 9 10)]
  39. >> 5.51922
  40. (fooInv f 50.0) ; a=1, b=10, n=99
  41. >> 5.52816 ; this result should be more accurate
  42.
  43. Proof
  44. (f 5.52816)
  45. >> 50.0 ; exactly
  46. |;
  47.
  48. ;|
  49. (_sin (/ pi 2.0))
  50. >> 1.0
  51. (rtos (/ pi 2.0) 2 20)
  52. "1.570796326794896"
  53. Interestingly I have this number from here : http://ronleigh.com/autolisp/ales15.htm
  54. 3.1415926535897932385 / 2 = 1.57079632679489661925
  55. (rtos (fooInv _sin 1.0) 2 20) ; a=1.570796326794891, b=1.570796326794901, n=10000
  56. Command: (rtos (fooInv _sin 1.0) 2 20)
  57. Specify minimal X value of looking interval : 1.570796326794891
  58. Specify maximal X value of looking interval : 1.570796326794901
  59. Specify segmentation of looking interval <100> : 10000
  60. "1.570796326794900" - but there is probably mistake as 00 were repeating at the end (it looks like (rtos) rounded last 6 digit up to 10) :
  61. Command: (rtos 1.57079632679489661925 2 20)
  62. "1.570796326794896" from this output it looks that that isn't the case...
  63. => PI = (rtos (* 2.0 1.570796326794900) 2 20) >> "3.141592653589800" - but there is probably mistake as 00 were repeating at the end
  64. |;
  65.
  66. (defun fooInv ( f b / args genargslst AddSpline AddLine L r )
  67.
  68.
  69.   (defun genargslst ( / a b n dx k r )
  70.     (setq a (getreal "\nSpecify minimal X value of looking interval : "))
  71.     (setq b (getreal "\nSpecify maximal X value of looking interval : "))
  72.     (initget 6)
  73.     (setq n (getint "\nSpecify segmentation of looking interval <100> : "))
  74.     (if (null n)
  75.       (setq n 100)
  76.     )
  77.     (while (= n 1)
  78.       (prompt "\nYou specified number 1 - that's not allowed...")
  79.       (initget 6)
  80.       (setq n (getint "\nSpecify segmentation of looking interval <100> : "))
  81.       (if (null n)
  82.         (setq n 100)
  83.       )
  84.     )
  85.     (setq dx (/ (- b a) (float n)))
  86.     (setq k -1)
  87.     (repeat (1+ n)
  88.       (setq r (cons (+ a (* dx (setq k (1+ k)))) r))
  89.     )
  90.     (reverse r)
  91.   )
  92.
  93.   (defun AddSpline ( 3DPtLst / r )
  94.     (cond
  95.       ( (not (vl-consp 3DPtLst)) )
  96.       ( (not (vl-every 'vl-consp 3DPtLst)) )
  97.       ( (progn (setq 3DPtLst (mapcar '(lambda ( x ) (if (= 2 (length x)) (append x '(0.0)) x)) 3DPtLst)) nil) )
  98.       (
  99.         (setq r
  100.             (vlax-safearray-fill
  101.               (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length (apply 'append 3DPtLst)))))
  102.               (apply 'append 3DPtLst)
  103.             )
  104.             (vlax-3d-point '(0. 0. 0.))
  105.             (vlax-3d-point '(0. 0. 0.))
  106.           )
  107.         ); setq r
  108.       )
  109.     ); cond
  110.     r
  111.   ); defun
  112.
  113.   (defun AddLine ( p1 p2 )
  114.       p1 p2
  115.     )
  116.   )
  117.
  118.   (setq args (genargslst))
  119.   (cond
  120.     ( (vl-some 'not (list f b args)) (prompt "\nInvalid arguments supplied.") )
  121.     (
  122.       (progn
  123.         (and
  124.           (not (vl-some (function (lambda ( x ) (equal b (f x) 1e-2))) args))
  125.           (prompt
  126.             "\nThe argument 'b' is not contained within f(x),
  127.             \nwhich may lead to not enough accurate result
  128.             \nalthough that would make this sub useless.
  129.             \n"
  130.           )
  131.         ); and
  132.         nil
  133.       ); progn
  134.     )
  135.     ( (vl-catch-all-error-p (vl-catch-all-apply (function (lambda nil (setq L (mapcar '(lambda ( x ) (list x (f x) 0)) args))))))
  136.       (prompt "\nThe supplied function 'f' errors out on some of the provided arguments.")
  137.     )
  138.     (
  139.       (vl-catch-all-apply
  140.         (function
  141.           (lambda ( / spl li )
  142.             (and
  143.               (setq spl (AddSpline L))
  144.               (setq li (AddLine (list (car args) (float b) 0.0) (list (last args) (float b) 0.0)))
  145.               (setq r (car (vlax-invoke spl 'InterSectWith li acExtendNone)))
  146.             )
  147.             (mapcar 'vla-Delete (list spl li))
  148.           )
  149.         )
  150.       )
  151.     )
  152.   ); cond
  153.   r
  154. ); defun
  155.
« Last Edit: April 28, 2020, 12:10:17 PM by ribarm »
M.R. on Youtube
ribarm
« Reply #28 on: April 28, 2020, 09:10:29 AM »
As you can see, I tried to get lastly digits of number PI by using custom (_sin) function based on Tyler order and this method - inverse function - that would be arcsin... But unfortunately there is probably some mistake - look into comments of my code I posted in previous reply...
[EDIT : Probably (rtos) rounded last digit which is initially 6 to up 10, so that result is correct, but not what I wanted...]
[EDIT : It seems that (rtos) is fine : (rtos 1.57079632679489661925 2 20) => "1.570796326794896"]
« Last Edit: April 28, 2020, 10:31:16 AM by ribarm »
M.R. on Youtube
jtoverka
« Reply #29 on: April 30, 2020, 12:03:58 PM »
So you have defined function - it could be as simple as (chr 65) => "A" ... Now we need to get (ascii) function from (chr), so that (chrinv "A") => 65 - the same as (ascii "A") => 65...
How complex are you willing to go? A two variable function can yield the same result with multiple inputs.
