Author Topic: Dark | Light Chocolate  (Read 3950 times)
« on: April 26, 2020, 12:47:04 PM »
In a recent LinkedIn post Sam Lucida discussed the creation of light and dark profiles to make it easy for him to switch between his working (dark mode) and documenting (light mode) environments. It's a great idea but I also thought it should be easy to toggle via a system variable, and it is:
(setvar 'colortheme (abs (1- (getvar 'colortheme))))
If you prefer a command simply:
(defun c:mode ( )
    (princ
        (strcat "\n"
            (nth (setvar 'colortheme (abs (1- (getvar 'colortheme)))) '("Dark" "Light"))
            " mode active."
Cheers.
Re: Dark | Light Chocolate
« Reply #1 on: April 26, 2020, 05:45:45 PM »
I guess you could also use (- 1 (getvar 'colortheme)) to avoid wearing out your abs.  :lol:
« Last Edit: April 26, 2020, 05:49:07 PM by Lee Mac »
DEVITG
« Reply #2 on: April 27, 2020, 06:23:30 AM »
Very nice MP, I love the way it seem.
« Reply #3 on: April 27, 2020, 07:56:09 AM »
Can I play?
You could also use (boole 6 (getvar 'colortheme) 1) to avoid wearing out your...math?
GDF
« Reply #4 on: April 27, 2020, 08:34:41 AM »
Nice
I would have called it Mood in lieu of Mode
(defun c:mode ( )
    (princ
        (strcat "\n"
            " mode active."
Cheers.
« Reply #5 on: April 27, 2020, 10:01:45 AM »
And ...
(defun c:Mood ( )
    ;;  M.Puckett, 2020 (inspired by Sam Lucido).
    (princ
        (strcat "\n"
            (nth
                (setvar 'colortheme (~ (- (getvar 'colortheme) 2)))
               '("Dark" "Light")
            " mode active."
« Reply #6 on: April 27, 2020, 10:48:58 AM »
Oh, you beat me to the BNOT. :)
« Reply #7 on: April 27, 2020, 11:00:25 AM »
as well as:
(rem 3 (+ 2 (getvar 'colortheme)))
(logand 1 (1+ (getvar 'colortheme)))
 :-P
Lonnie
« Reply #8 on: April 27, 2020, 11:14:52 AM »
Along those lines.
When asked to customize the colors for the company.
(setq acadobject (vlax-get-acad-object))
(setq acadpref (vlax-get-property acadobject 'preferences))
(setq acaddisp (vlax-get-property acadpref 'display))
(vlax-put-property acaddisp 'GraphicsWinmodelBackgrndColor 65986) ;;Model space background
(vlax-put-property acaddisp 'GraphicsWinLayoutBackgrndColor  63434) ;;command area
(vlax-put-property acaddisp 'ModelCrosshairColor 865785);; crosshairs
(vlax-put-property acaddisp 'TextWinBackgrndColor 3687) ;;command area
tombu
  • ByLayer=>Not0
« Reply #9 on: April 27, 2020, 11:16:48 AM »
Add CUI macro
Set Display Name to:
$(if,$(=,0,$(getvar,colortheme)),!.)Dark ModeSet Macro:
^P(ai_onoff "colortheme") ^P
Tom Beauford P.S.M.
« Reply #10 on: April 27, 2020, 03:19:57 PM »
wizman
« Reply #11 on: May 24, 2020, 06:10:57 AM »
Gents, thanks for your solutions. Just adding to the collection,
(setvar 'colortheme (1+ (- (getvar 'colortheme))))
(setvar 'colortheme (lsh 1 (- (getvar 'colortheme))))
(setvar 'colortheme (nth (getvar 'colortheme) '(1 0)))
(setvar 'colortheme (fix (distance '(1 0 0) (list  (getvar 'colortheme) 0 0))))
