Author Topic: Solid Models: freeze/fatal error  (Read 3206 times)
cad-waulader
« on: June 15, 2005, 03:55:54 PM »
Hello all.  Anybody have trouble with 2000 when working with solid models?  I do...get freezes and fatal errors all the time.  maybe i'm doing something wrong, but I can't imagine what.  panning and rotating models is a great way to crash.  Co-worker's computer does the same thing with 2000.  appreciate any input.
CADaver
Re: Solid Models: freeze/fatal error
« Reply #1 on: June 15, 2005, 04:00:16 PM »
Haven't had the trouble but I've heard of others having trouble with large XREFs and ALL the osnaps set, or hatching associated with xref'd elements.
cad-waulader
« Reply #2 on: June 15, 2005, 04:04:51 PM »
nope, no xrefs & skimpy on the osnaps. hmmm!
CADaver
« Reply #3 on: June 15, 2005, 05:18:40 PM »
Low system resources?  What's yer computer setup?
Anonymous
« Reply #4 on: June 15, 2005, 05:32:52 PM »
OK.  I'm not real computer savvy, but here's what I know:
"PentiumIII" (From sticker on front of computer!)
"392,740 KB RAM" available, as read from Control panel>System>General tab
"Virtual memory: 576 MB total paging file size for all drives" as read from Control panel>System>Advanced>Performance Options tab.
That help?
cad-waulader
« Reply #5 on: June 15, 2005, 05:35:11 PM »
BTW, "Guest" above is me.  login didn't take.
CADaver
« Reply #6 on: June 15, 2005, 06:13:42 PM »
Well that's about half the machine you need, if you're gonna be serious about 3D.
I'm running a P4, 2.4Ghz, 1.5Gb RAM machine with Virtual memory set at 1024Mb, and it's just enough for our bigger files (100Mb)
cad-waulader
« Reply #7 on: June 15, 2005, 06:40:23 PM »
thanks.  may as well upgrade it.
t-bear
« Reply #8 on: June 16, 2005, 09:44:51 AM »
Not "may as well......" you NEED to upgrade!  We do 3D here too and I'm b***ching all the time 'bout this POS P4 w/only 1g of memory & 128m vid card!
