Author Topic: Creating 3D Text and Wrap it Around a Pipe (Cylinder)  (Read 8353 times)
MickD
Re: Creating 3D Text and Wrap it Around a Pipe (Cylinder)
« Reply #30 on: May 15, 2020, 01:31:26 AM »
maybe a regen might work.
I've never really worked with Record/ShowHistory, maybe the ShowHistory is leaving the wireframe for you??
- John Carmack
- J.R.R. Tolkien
MickD
« Reply #31 on: May 15, 2020, 01:39:28 AM »
It seems that setting ShowHistory to true may be what is confusing the output, from the doc's:
Returns whether items in the history should be drawn when the sysvar SHOWHIST is 1.
Try setting SHOWHIST to 2 after running the method.
and https://www.youtube.com/watch?v=KjbxXeFYknw
- John Carmack
- J.R.R. Tolkien
flyte
« Reply #32 on: May 19, 2020, 10:46:07 AM »
Thanks once again MickD. I think I've finally got it. Now I just need to tweak the text placement. Your assistance was very much appreciated!
MickD
« Reply #33 on: May 19, 2020, 05:30:42 PM »
Noice!
It was good to think about this stuff again, it's been a while :)
- John Carmack
- J.R.R. Tolkien
