how can I start with .NET?
for example:
for lisp, I search similar lisp to my needs, then I change Line 3 and Line 4
for .NET, I tried to search for some code that simulates REPLACEBLOCK command, for replacing in AutoCAD MEP, Devices for blocks and vice-versa, no luck.
for .NET again, I tried to search for some code that converts polylines to Conduit or Cable Trays Objects vice-versa, in AutoCAD MEP, but no luck.
then some questions:
1 How can I start since zero to create both codes in NET?
2 Why does it not exist code in NET for common problems?
3 Is NET or AutoCAD MEP begin deprecated and replaced for REVIT and Dynamo?
