I need to change the color by elevation properties, I found some lisp, I need to use all colors and limit the elevation range
image 1;
In image 1, I need to set a limit the max elevation to 11000 and minimal in 1000, blue for the highest and red for lower, in the middle green, I mean RGB, and If possible use DCL to let the user choose colors. I need to use all the colors range in the Index Color pallet. Anyone can help me?
image 2
links:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-for-coloring-entities-by-elevat...
https://www.theswamp.org/index.php?topic=51064.0 here an example:
(defun c:zmap ( / cma cmi del elv enx idx lst pct rng sel zmn zmx )
(setq cmi '(255 0 0) ;; Minimum colours
cma '(255 255 0) ;; Maximum colours
zmx 0.0
zmn 0.0
(if (setq sel (ssget "_:L" '((0 . "LINE,LWPOLYLINE"))))
(repeat (setq idx (sslength sel))
(setq enx (entget (ssname sel (setq idx (1- idx))))
elv (if (= "LINE" (cdr (assoc 0 enx)))
(max (cadddr (assoc 10 enx)) (cadddr (assoc 11 enx)))
(cdr (assoc 38 enx))
lst (cons (list enx elv) lst)
zmx (max zmx elv)
zmn (min zmn elv)
(setq rng (mapcar '- cma cmi)
del (- zmx zmn)
(if (equal 0.0 del 1e-8)
(princ "\nNo change in elevation.")
(foreach itm lst
(setq pct (/ (- (cadr itm) zmn) del))
(entmod
(append (car itm)
(list
(cons 420
(apply 'LM:rgb->true
(mapcar '(lambda ( a b ) (+ a (* b pct))) cmi rng)
;; RGB -> True - Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->True ( r g b )
(logior (lsh (fix r) 16) (lsh (fix g) (fix b))
