Author Topic: Convert one csv file to another with lisp  (Read 1742 times)
PM
« on: April 01, 2020, 08:19:19 AM »
Hi. I have test.csv file  and i want to convert it to test2.csv. Is any way to do this with lisp. I try to do it in excell but i can not find a fast way to do this. I did it manualy. But when i have a lot of rows with data is difficult.
ribarm
  • Marko Ribar, architect
Re: Convert one csv file to another with lisp
« Reply #1 on: April 01, 2020, 09:19:53 AM »
Here you go...
  1. (defun c:csv-pts-2-csv-pts+hor-proj ( / f1 fn1 l lst lstpairs p1 p2 p3 lstt f2 fn2 )
  2.   (setq f1 (getfiled "Select PTS CSV file..." "\\" "csv" 16))
  3.   (setq fn1 (open f1 "r"))
  4.   (while (setq l (read-line fn1))
  5.     (setq lst (cons l lst))
  6.   )
  7.   (setq lst (reverse lst))
  8.   (foreach l lst
  9.     (setq lst (subst (list (atof (substr l 1 (vl-string-search "," l))) (atof (substr l (+ 2 (vl-string-search "," l))))) l lst))
  10.   )
  11.   (setq lstpairs (mapcar '(lambda ( a b ) (list a b)) lst (cdr lst)))
  12.   (foreach pair lstpairs
  13.     (setq p1 (car pair) p3 (cadr pair))
  14.     (setq p2 (list (car p3) (cadr p1)))
  15.     (setq lstt (cons p1 lstt) lstt (cons p2 lstt))
  16.   )
  17.   (if (not (vl-position (last lst) lstt))
  18.     (setq lstt (cons (last lst) lstt))
  19.   )
  20.   (setq lstt (reverse lstt))
  21.   (setq f2 (getfiled "Select PTS with HOR-PROJ CSV file..." "\\" "csv" 1))
  22.   (setq fn2 (open f2 "w"))
  23.   (foreach pt lstt
  24.     (write-line (strcat (rtos (car pt)) "," (rtos (cadr pt))) fn2)
  25.   )
  26.   (close fn2)
  27.   (startapp "EXPLORER" f2)
  28.   (princ)
  29. )
  30.
HTH., M.R.
M.R. on Youtube
« Reply #2 on: April 01, 2020, 09:44:35 AM »
Don't mind me; I had a quick moment and I wanted to try to write a routine to merge lists (what I thought is the core of the problem). This was me just playing with AutoLisp.
  1. (setq lst1 '(1 2 3 4)
  2.       lst2 '(5 6 7 8))
  3.
  4. ( (lambda ( lst1 lst2 )
  5.     (apply 'append
  6.            (mapcar 'append
  7.                    (mapcar 'list lst1)
  8.                    (mapcar 'list lst2)))
  9.     )
  10.     lst1
  11.     lst2
  12.   )
> (1 5 2 6 3 7 4 8)
PM
« Reply #3 on: April 01, 2020, 01:55:12 PM »
Thank you ribarm
« Reply #4 on: April 01, 2020, 02:42:17 PM »
Nice one John - I miss the old 'challenge' style academic threads which focussed more on fundamental programming technique and your post reminded me of them.  :-)
FWIW, you could omit one level of nesting from your code to achieve the same result, i.e.:
  1. _$ (apply 'append (mapcar 'list lst1 lst2))
  2. (1 5 2 6 3 7 4 8)
« Reply #5 on: April 01, 2020, 02:53:25 PM »
Yeah, they were a lot of fun and very, very helpful.
Ugh! That's what I was trying to do in the beginning (well, at least that is how I tried to "think out the method" like I used to be able to do). Thanks! :) ...I had a problem and it eventually morphed into that mess (my luck, I probably just misspelled "mapcar" and could have saved a few brain cells).
« Reply #6 on: April 01, 2020, 04:04:35 PM »
The transformation reminds me a lot of a matrix transposition, e.g.:
  1. _$ (setq m '((0 1 2) (3 4 5) (6 7 8)))
  2. (
  3.     (0 1 2)
  4.     (3 4 5)
  5.     (6 7 8)
  6. )
  7. _$ (apply 'mapcar (cons 'list m))
  8. (
  9.     (0 3 6)
  10.     (1 4 7)
  11.     (2 5 8)
  12. )
Except that in this case, we are flattening the resulting list -
  1. _$ (setq m '((1 2 3 4) (5 6 7 8)))
  2. (
  3.     (1 2 3 4)
  4.     (5 6 7 8)
  5. )
  6. _$ (apply 'mapcar (cons 'list m))
  7. (
  8.     (1 5)
  9.     (2 6)
  10.     (3 7)
  11.     (4 8)
  12. )
  13. (1 5 2 6 3 7 4 8)
« Reply #7 on: April 01, 2020, 04:40:40 PM »
Continuing down the rabbit hole...
speaking of matrices, they remind me of safearrays.
  1. (vlax-safearray->list (vlax-make-safearray vlax-vbString '(0 . 2) '(0 . 2)))
And that, is the extent of my memory on that subject (that is all you guys get from me on sfearrays).
