Author Topic: Insert block with attribute in middle of line with field value.  (Read 1364 times)
jtm2020hyo
I need to insert a block with  ATTRIBUTE( or TEXT, MTEXT, RTEXT, DTEXT) in the middle of the selected lines, but with the field of length, layer, line type, etc. any selected field but of each selected line individually
related link:  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/modify-mmp-lisp-to-insert-attribute-text-mtext-rtext-dtext/m-p/9385885#M397369
inspired by Lee Mac: http://www.lee-mac.com/midlen.html
attached MMP, a lisp very similar to my request and a drawing with my representation.
PD: if possible use DCL.
BIGAL
  • 40 + years of using Autocad
Re: Insert block with attribute in middle of line with field value.
« Reply #1 on: March 30, 2020, 02:54:37 AM »
Using a  (vlax-curve-getfirstderiv  obj  (vlax-curve-getparamatpoint you can return the angle at that point so will be tangent to an arc just convert to 90 direction and like Lee check for readability.
So should be able to change lee's code pretty easy.
(defun alg-ang (obj pnt)
  (angle '(0. 0. 0.)
       obj
         obj
         pnt
jtm2020hyo
« Reply #2 on: March 30, 2020, 01:59:19 PM »
  (angle '(0. 0. 0.)
       obj
         obj
         pnt
thanks a lot for your reply. exist any way to insert any type of field related to the polyline? like length, line type, layer, or anything.
